Old 06-24-2008, 11:32 PM   #1
Meridian , Mississippi
convertor question
I own a 1972 Avion. When I bought it the convertor wires were cut. I fiqured out how to hook the battery up in the box outside and through a shunt in side. Some of the lights are working off just the battery. There is a blue wire, red wire and white coming out of the convertor. I hooked up the blue and red but there is nothing to hook the white up to. Since the were cut I dont know where it goes. I believe this is why some the the lights arent working. I know the white is negative but where do I wire it to? Thanks for any help.
Dana13 is offline   Reply With Quote
Old 07-20-2008, 10:10 AM   #2
1976 25' Caravanner
Campton , New Hampshire
This is probably too late for you but the white wire is usually ground to the trailer, anywhere you have good connection to metal and/or frame. I'm just starting on an Avion TC.
ticki2 is offline   Reply With Quote
charge convertor 31airstream Batteries, Univolts, Converters & Inverters 2 06-12-2007 06:03 PM
New Progressive Dynamics convertor, AGM battery, and Pendant questions wacnstac Batteries, Univolts, Converters & Inverters 16 05-09-2007 09:12 PM
power convertor ifly4cal Electrical - Systems, Generators, Batteries & Solar 4 12-07-2005 08:40 AM
Convertor question - 2005 Classic Pappy 2001 - 2005 Classic 2 05-30-2005 09:42 PM
New power Convertor HOT! silverbullet Electrical - Systems, Generators, Batteries & Solar 4 09-24-2002 10:01 AM
