Old 07-29-2010, 10:55 AM   #1
wbcci3371's Avatar
1993 34' Limited
Scituate , Massachusetts
Converting Slimline Flourescent Fixtures to LED
Does anyone have a less expensive solution to upgrading the little 2-tube Slimline fluorescent light fixtures to LED?
From what I have seen on various sites plus the Airstream store, they are about $20 for each strip or about $50 per fixture shipped. Seems to me there ought to be something a bit less expensive out there.
Thanks!
Rich
wbcci3371 is offline   Reply With Quote
Old 07-29-2010, 11:08 AM   #2
_
the led strips used inside the flo' fixtures (after by passing the ballast)
are ALL priced ~20-25 bucks PER TUBE replacement.
have u price ANY led bulb replacements for any of the fixures?
they are all spendy after 4-6 LE DIODES are used.
there ARE some less expensive flo' bulb conversions,
but they all involve fewer OR dimmer ledz.
__________
and just an fyi, after converting 6 flo' fixtures...
it takes 3 strips (not 2) or 60-75$ worth...
to get approximately the SAME brightness and spread of light...
as the original flo' bulbs.
___________
flo bulbs tend to FADE with age, so when replacing OLD FLO,
2 strips seems about equal,
but compare 2 strips to FRESH/NEW flo' bulbs
and 2 strips is clearly not as much light as 2 flo'...
and flo' bulbs run ~5$ for good replacements.
i was burning through 1-3 bulbs per year in some fixtures (like over the fridge and sink)
___________
i DO expect prices to drop significantly on the led strips...
but the price drop won't happen till after we convert them...
cheers
2air'
Plating of fixtures RankAm Ribs, Skins & Rivets 0 07-29-2009 10:30 PM
Thinlite 12Vdc Flourescent lights Calvin Electrical - Systems, Generators, Batteries & Solar 3 04-19-2007 01:12 PM
ac light fixtures roadtrip07 Electrical - Systems, Generators, Batteries & Solar 1 10-24-2005 12:39 PM
Falling flourescent light covers Pahaska Electrical - Systems, Generators, Batteries & Solar 4 01-16-2004 05:36 PM
'75 Excella flourescent lights davidz71 Electrical - Systems, Generators, Batteries & Solar 2 04-05-2003 08:23 PM
