Old 08-13-2003, 10:29 AM   #1
Lexxy's Avatar
1973 23' Safari
Brevard , North Carolina
Images: 16
converter wiring
Would somebody double check this arrangement and see if it looks OK to them?
I'm not absolutely sure and would appreciate an opinion or two!!!
Lexxy
After circumnavigating on 40' sailboat, cruising the USA in our '73 Safari, Tara!
Lexxy is offline   Reply With Quote
Old 08-13-2003, 04:45 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
looking good
lexxy
that plan looks good to me.
do you still have the original control panel? if so, you may want to add the shunt for the ammeter.
also, you could add a indicator light that would come on when you are on shore power.
a 120 volt lamp that comes on with the converter, mounted in a convienent location would do.
some where in the kitchen area, perhaps on the side of a cabinet.
john
Old 08-13-2003, 04:54 PM   #3
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
One thing ...
I would add to one of the 12v circuits is a cigarette-lighter type output in a convenient place. You can buy them at Wally Mart, etc. You can use the 12v outlet to plug in a hand-held vacuum cleaner, an inverter, or other handy things.
My trailer came with one 12v outlet for the TV and I have installed additional 12v outlets in the galley and in the bedroom. When dry camping, I use the bedroom outlet to power my inverter, which in turn powers my laptop.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 08-14-2003, 05:27 AM   #4
Lexxy's Avatar
1973 23' Safari
Images: 16
I do have some 12v plugs....they just weren't listed.
About the ammeter...what does it do and what's a shunt? Where would I put it. I have a thing that reads the battery power in an upper foward cabinet but I don't know where the wires go.
This is just a guess at the electricity based on what was there when I got it and I don't know if that worked cuz we didn't get a battery until now. This A/S was on $300 so wer didn't complain.
Lexxy
Old 03-15-2009, 06:36 PM   #5
PetesPup's Avatar
1989 32' Excella
Meridian , Idaho
I hope you are using a True Sine Inverter. Otherwise, you will fry your laptop battery & recharging ability.
PetesPup is offline   Reply With Quote
trailer side brake wiring diagram? munimula Brakes & Brake Controllers 9 03-26-2017 09:53 AM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 12:38 PM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 06:52 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 08:45 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
