Old 09-28-2012, 01:33 PM   #1
2008 28' Safari SE
1997 25' Safari
1976 25' Tradewind
Elgin , Arizona
Converter outlet plug bad? 1997 Safari
With no lights or other d/c powered items with the trailer on AC and battery offline, the dealer said bring it in you have a bad converter. To be certain--I followed the advice from my converter's manf. and first tested the a/c outlet it is plugged in to. No juice and when I used an ample guage extension cord to a different outlet, voila, I had a good converter with lights, etc. I'm new at this, but persistent. I managed to remove the outlet for the converter from the rear wall under the sofa bed , but it's a solid unit. You probably can take it apart, but worried it would bust. Do these outlets go bad, or is this likely a more problematic wiring issue? I have an appointment to bring to dealer on Monday,but prefer to address on our own if possible---know my limitations in this area.
Thanks for help/suggestions.
Hankster is offline   Reply With Quote
Old 09-28-2012, 01:47 PM   #2
1974 Argosy 20
Kooskia , Idaho
The RV outlets often are a special one, which does not use a box behind it. The wires are also a push in connection. New ones are available at a fully stocked RV store.
I assume you checked the circuit breakers in the main box to see that all are on. To be sure, turn them off, then back on again. When they trip they often go to a neutral space and look like they are on, but are not. They reset by turning fully off, then on again. if they are GFI circuit breakers they reset the same way. The "test" button will trip them out and then they need to be reset by the Off then ON cycle.
Old 09-28-2012, 01:50 PM   #3
Ag&Au's Avatar
Port Orchard , Washington
In our trailer, the outlet for the converter is on a separate circuit breaker. In the A/C circuit breaker box, make sure all the breakers are on. If you can identify which one is for the outlet you are working on, reset it.
It is unlikely that the problem is in the outlet itself, but it is possible.
Ken
Old 09-28-2012, 01:57 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
In my 1983 Excella, the converter outlet is on the GFCI breaker. This breaker also supplies power to the exterior and bathroom outlets. Do you have power to these outlets?
Note: the converter outlet is at the opposite end of the trailer, physical proximity has nothing to do with it.
Vaughan
Old 09-28-2012, 03:24 PM   #5
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Our '95 has a switch behind a curtain for turning the converter outlet on and off. It looks like a light switch in a house. Look for one of those (check your manual).
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-29-2012, 08:17 AM   #6
2008 28' Safari SE
1997 25' Safari
1976 25' Tradewind
Elgin , Arizona
No manual- I need to try and find one, but that was it. Thanks much. You saved me a lot of time and embarrassment in taking it 70 miles to the dealer!
Old 09-29-2012, 08:20 AM   #7
2008 28' Safari SE
1997 25' Safari
1976 25' Tradewind
Elgin , Arizona
Thanks skeeter. That was it. No manual- I need to try and find one- obviously.
Old 10-01-2012, 05:37 AM   #8
Skater's Avatar
1995 30' Excella
Bowie , Maryland
No problem. You should've seen me on our first trip with our trailer last summer, when both electrical systems shut down because the batteries got too low (it's a quirk caused by how our inverter is wired). I was like, "This shouldn't be happening! We still have shore power!"
Then I found the switch...
'64 Safari Converter Question Fan/Pump Switch Castiniron Batteries, Univolts, Converters & Inverters 6 09-15-2011 07:24 AM
30 amp plug into 50 amp welder outlet? flyfish Electrical - Systems, Generators, Batteries & Solar 17 07-06-2011 03:56 PM
Wet weekend in our Safari OR How I discovered the Blow Out Plug! Brow324 Plumbing - Systems & Fixtures 16 04-18-2011 11:15 AM
Exterior outlet on '04 Safari DJW Electrical - Systems, Generators, Batteries & Solar 6 01-23-2011 07:17 PM
