Old 08-05-2013, 04:28 PM   #1
Johnco's Avatar
2006 19' Safari
Anaheim , California
Converter mystery
Here's one for the electrical experts. Early last year I replaced the converter in my 2006 Bambi with Best Converterís Ultra III converter and 3 stage charger. I monitor my batteries with a Voltminder plugged into the lighter receptacle at the TV. Up to this point when Iím plugged into 110 the Voltminder reads out 13 plus volts (both with the original converter and the new one). This weekend while camping with hook-ups the Voltminder alarm went off and was showing 11.8 volts. I got my tester out and checked the voltage from the converter at the fuse panel and itís reading 13 plus volts. I checked the batteries and they are barely holding 12 volts, so I guess they are shot, but even if the batteries were gone shouldn't the voltage still be registering higher at the Voltminder while plugged in?
Johnco is offline   Reply With Quote
Old 08-05-2013, 05:15 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Not necessarily, you would think so but corroded connections at the battery or a bad ground connection where the battery attaches to the chassis would cause the battery not to charge and show low voltage at the battery.
Garry
