Old 02-20-2012, 03:06 PM   #1
1997 31' Land Yacht
Congress , Arizona
Smile Converter is found on 1997 Land Yacht Motorhome
The converter is found!! It is located in the extreme right hand side (passenger side) upper corner under/behind the dash board.
There is a double AC outlet just to the left of it that it plugs into. The AC circuit breaker for this converter is labeled "BEDROOM/CONVERTER". The AC circuit breaker panel is under the foot of the bed.
Without taking out the dashboard, I could not determine its size, so will not worry about it unless it fails.
Thanks to everyone who looked or responded to my question.
Kendall is offline   Reply With Quote
Old 02-20-2012, 03:36 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
2000 Land Yacht 30(31') , Inverness, between the Withlachochee River and the Gulf of Mexico, Fl
Removing the panel that is across the footwell and with a mirror you should be able to identify model. I found my panel had 4 screws imbedded in the carpet gave good access to a/c vent manifold. Found an unused a/c vent, piped it over to the drivers gas pedal area, now Driver is comfortable, too.
Clipper, Cutter, Land Yacht, Interior Updates masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 14 04-24-2012 03:55 PM
Need info on WBCCI number on AS nascar427 WBCCI Forum 16 02-21-2012 03:23 AM
Is a wide body actually wider? farmerdave Buyer Guidelines 11 02-20-2012 10:46 PM
How long is it? casa3805 Buyer Guidelines 7 02-20-2012 07:10 AM
