Old 04-16-2014, 08:49 PM   #1
Severna Park , Maryland
Converter, Furnace, Or Batteries
Got our 2009 28' Flying Cloud out of winter storage today and was testing systems. The trailer is plugged into AC power. Had the halogen lights on in the trailer and turned the furnace thermostat up enough to start it up. When the furnace fan started, the lights noticeably dimmed. The gas/burner firing and cutting off had nothing to do with it. I have a plug in analog AC voltage meter and the AC voltage to the trailer is fine.
Don't know if this is relevant; but, the batteries are starting their 5th season. Running the furnace was immediately knocking the DC voltage down to 12.4 volts and the batteries seemed fine running the power jack up and down earlier today.
Should be obvious by now that I'm electrically challenged and feel sure someone can give the me "order of business" to start isolating my problem. Thoughts and ideas will be appreciated.
sailorii is offline   Reply With Quote
Old 04-16-2014, 09:19 PM   #2
SteveH's Avatar
Common Sense , Texas
I'd almost bet you need new batteries.
Regards,
Steve
Old 04-16-2014, 09:32 PM   #3
1974 Argosy 20
Kooskia , Idaho
Probably time for new batteries but your converter/charger may also be on it's last legs. The thing which makes me say that is the voltage you report of 12.4 under a load. The converter/charger should keep that up to 13.5 or 13.6 . You do have the USE/STORE switch in the USE position I hope. If you forgot that, all bets are off.
Old 04-16-2014, 09:38 PM   #4
2014 23' Flying Cloud
Reed Point , Montana
I'd also bet you need new batteries, and this might be an excellent time to upgrade your converter to a 3 stage system.
Bigskyrider8 is offline   Reply With Quote
Old 04-18-2014, 02:44 PM   #5
Thanks responders! At about 10pm my time, night before last, I posted my problem here. The next morning I had my answers. What a good resource this site is.
Yep, the batteries were toast. And, I had not already replaced the original converter. Replaced the batteries. Had the converter tested and the output was below spec. Before sundown yesterday, had a new multiple stage converter installed. Back in business!!
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
factory supplied converter and batteries rayandre Batteries, Univolts, Converters & Inverters 9 02-23-2011 05:47 AM
New converter and batteries flsafari Electrical - Systems, Generators, Batteries & Solar 19 04-30-2006 04:04 PM
Batteries Short...New Converter robandzoe Electrical - Systems, Generators, Batteries & Solar 25 03-22-2005 11:38 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
