Old 12-23-2018, 08:14 PM   #29
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by 68 Overlander View Post
Bulk, Absorption, float and desulfation. Wait that's 4!
I suppose you could argue which mode single voltage type converters like the Parallax and all previous "Univolts" were "in" I would go with...they stay between bulk and absorbtion at their 13.8 VDC. Parallax did have a T model that has a long 12 or 14 hour (I forget which) timer that it stayed on bulk at 14.X VDC but don't think Airstream used them. Somebody can correct me if they had one. I didn't care for them.
Which data sheets Bob? Airstream used Parallax exclusively in the trailers for over a decade except the trip-lite in the Interstate models maybe? Might be others I'm not aware of.
Hi
Ok quick translation to what each means:
1) bulk = constant current / current limited charge
2) Absorption = constant voltage charge once a set voltage is reached.
3). Float = drop back voltage once you hit a preset point.
4). Desulf = boost voltage to move things around
The first two are what *every* converter has been doing for a long long time. If
you get to three or four total, the first two *have* to count !!!
The gotcha with float is that magic term "preset point". Maybe it's a 48 hour timer. Maybe it's a 0.25 A current drain. Maybe it's a combination of the two. There is no single definition of what that point is or should be. How well it matches this or that ..... who knows .... AS converters have had float for quite a while .... How well it works is a different point ....
Old 12-23-2018, 09:49 PM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Actually AS has been using a two stage converter ever since they started using converters.
Stage one...they work.
Stage two...they don't.
The stages can reverse at any time. 🥴
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 12-23-2018, 10:27 PM   #31
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
The stages can reverse at any time. ��
Hi, after thirteen years, my converter is still on stage one.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-24-2018, 12:27 PM   #32
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Here we go again! UB; you might call AS and tell them they have been supplying multi-stage converters all these years, and did not need to change to the new 3 stage converters recently! Because....when you talk with AS service in Ohio, or the dealers service departments in CA, TX, and MT, they also are not aware...they all say it was a single stage unit...maybe their just ignorant...but that's what they say. No comparison to the 4 stage unit from Boondocker or Progressive D!ynamics 4 stage units...sorry, but this argument is getting old.... I agree with RCross above...Stage one they work; stage 2 they don't!
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 12-24-2018, 01:38 PM   #33
New Borockton , Alabama
Images: 21
Hi Bob,
There is really no magic to the point when the converters drops to float. The 4 stage units drop to float after a 30 hour time out of virtually no voltage change. People call all the time and say its been 36, 48, 3 days or a week and my converter still has not dropped back so there must be something wrong with it. What they miss is the part of no significant voltage change. Can't stress this enough as the most misunderstood part of the float on these units.
If you are "using" your RV, you will not see float ever unless you manually force it. The automatic setting is watching for no voltage change. PD is set at ~.3 VDC so if you are using the unit, you will constantly be re-setting the timer.
If you store the unit with shore power and forget a week later you left a 6 pack in the fridge and go retrieve it, open the door, turn on a couple lights, open the fridge, glance at the battery monitor or charge wizard LED thinking is should be in float, well it probably was about a minute ago before you woke it up and it's back to normal/absorption and the timer starts over.
Sometimes the LP and CO detectors can affect the voltage enough as well.
Another thing worth noting is the desulfation cycle only works in the float mode so it's sometimes hard to catch it unless you have a battery monitor that logs the history.
It's pretty cut and dry how they work and thanks for bringing it up. Hopefully this helps somebody.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 12-25-2018, 06:48 AM   #34
Half a Rivet Short
Hi
There's no need to call AS and tell them, they have shown that's they put in multistage converters in the manuals for the chargers for a long time. It's not at all news to them. If you talked to them over the years, they were quite happy to point that out. There are posts to that effect.
There is indeed magic in terms of going to float. You don't want to drop back before the charge is done. Some do it one way, others do it another way. The idea is to get as close to full charge as you can. Some use a current cutoff. Others use time plus current.
Much of what is seen on the "stock" chargers is related to their funky approach to float. Their current limit is set at a point that it is easy to stay above. There are a *lot* of chargers out there with the same problem. For whatever reason, they also have a pretty long timer on them. That super long timer is not as common. The combo of the two is weird.
Feel free to call them weird or stupid. That's pretty accurate. Calling them "single stage" is not correct.
Relocation / upgrade of 1982 converter/charger Cindy Picton Batteries, Univolts, Converters & Inverters 0 12-06-2018 06:21 PM
Charger converter fan not stopping Jukeboxfun Electrical - Systems, Generators, Batteries & Solar 32 04-12-2016 07:32 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Progressive Dynamics Intelli-Power 4600 charger upgrade module rodsterinfl Batteries, Univolts, Converters & Inverters 1 09-05-2013 05:57 AM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
