Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-16-2002, 10:47 AM   #1
Profile:
Converter Breaker?
Yesterday after reading about how some of you wanted to d/c the converter from the 110volt home hookup after the batteries are up to 12.7 volt and fully charged.
So I went out and started throwing breakers. There are 4 on my 110 volt box in the back above the twin bed. Seems the second one from the top is the master and the bottom one which looks to be a GFI breaker is the one which shuts off the converter.
Tripping the GFI breaker shuts off the converter but also cuts elec to the 110 in the back and also in the bath.
I haven't run the wires yet to see if I could spit that breaker out to just the converter. There is an extra slot at the top for a fifth breaker that could be added. I assume the converter is on the GFI for a very good reason.
Anybody done this or is it easier to put a knife switch in front of the converter to cut it off? I would rather charge the batteries up on the larger home unit (20amp and 40 amp).
Steve in Savannah
Sav'h Steve is offline   Reply With Quote
Old 11-16-2002, 11:20 AM   #2
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
My converter is NOT on the GFCI. My converter is plugged into a wall outlet under the couch. It's on the same circuit as the rest of the living room, under the dinette, and the bedroom.
The GFCI controls the kitchen, bath, and outdoor outlets.
The AC has a breaker of its own.
And then there's the main breaker.
I forget off-hand which breaker the microwave is on.
The converter is an inductive load (a big transformer). Seems to me that could cause problems for the GFCI (voltage leads current through an inductive load... ELI the ICE man don'tcha know .
Maurice
AB8XA
AIR # 804, WBCCI 5446
The Long, LONG Trailer
Paralleled Honda EU2000i
Old 11-16-2002, 01:39 PM   #3
Profile:
Thanks for the reply Maurice..
I need to go back out and check all the outlets and find which are on each breaker. It's pouring rain outside here in Sav'h now. Have ta wait a while!
I would think the 34' has more breakers than the '4' I have.
Still I am thinking the best way to cut it off and keep juice to the TT is to use a knife switch or such.
Any recommendations?
Steve in Sav'h GA
Old 11-16-2002, 02:55 PM   #4
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
since a seperate circuit from the breaker is out of the question becuase the outlets are daisy chained together, how about a 15 amp wall switch installed next to the main battery switch.
you could cut the wall switch into the power cord. then you could just reach behind the couch and flip it off without affecting anything else.
if your trailer is like mine there should be a wood shelf behind the couch that would give you enough room for a switch and cover plate.
if your cord on the converter is not long enough you could just make an extention cord with the switch and outlet on one end.
john
Old 11-16-2002, 03:02 PM   #5
Beavercreek , Ohio
I'll bet it isn't 36 degrees and rainy in Savannah right now! YUK!
First, I'd look at how much voltage that particular converter puts out once the batteries are charged. If it's between 13.2 and 13.6V, I'd just leave it hooked up all the time. That's the typical fixed voltage float charge of most battery chargers I've seen. Just check the water level periodically.
If you disconnect the converter at the AC side, I wouldn't use an exposed knife switch... put a box in the AC line and a switch in it sufficient to handle the current of the inverter.
I wouldn't disconnect the batteries themselves if you're gonna leave the trailer AC live. Many converters have poor, if any, filtering after rectification to DC, and rely on the batteries to absorb most of the AC ripple. Having that going to your 12V appliances wouldn't be a good thing.
Maurice
AB8XA
Old 11-17-2002, 10:01 PM   #6
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Converter
Steve,
My Magnatek converter/charger sits underneath the entertainment center underneath the front window of my '77 31' Excella 500. There are two 110 volt receptacles within the center, one of which the converter is plugged into. When I feel a need to shut the converter off to prevent overcharging of batteries, I just pull the plug.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 11-18-2002, 09:42 AM   #7
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
My coach has blade switches on the two coach batteries. If I disconnect these I am cutting off the charger from the batteries... This would allow me to plug into shore power and NOT charge them, so as to avoid overcharging.
Wouldn't be a problem for the charger to have them disconnected?
Old 11-18-2002, 09:45 AM   #8
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
Univolt Facts
No damge according to Andy at Inland.
See thread Univolt Facts.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
circuit breaker pops ... eubank Electrical - Systems, Generators, Batteries & Solar 3 01-30-2004 12:37 PM
Converter busted? Navigator Electrical - Systems, Generators, Batteries & Solar 4 01-06-2004 11:22 AM
Power converter "fuse" rfield54 1999 - 2004 Bambi 0 09-02-2003 03:26 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 11:52 AM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 07:52 AM
