Old 05-25-2015, 08:22 PM   #1
1976 31' Sovereign
Easley , South Carolina
Converter
need advice on changing out converter on 76 airstream......whats the best and can i leave old fuses in or does that have to be updated too?
parisman57 is offline   Reply With Quote
Old 05-25-2015, 09:24 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I will recommend a Progressive Dynamics 9245 converter. Along with replacing the fuse panel with one of the new blade type.
Old 05-26-2015, 05:35 AM   #3
1976 31' Sovereign
I know where to get the converter but where could I buy the fuse panel?
Old 05-26-2015, 07:04 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The same place should have them.
MICHAEL
Old 05-26-2015, 07:06 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Type in "12 Volt Fuse Panel" on the Internet. Look on eBay, etc.. Pick one with enough circuit capacity (the number of wires from your old fuse panel".. Rated for at least 50 amps of total load. A 9245 converter is rated for 45 amps.
Some automotive stereo shops and auto parts stores carry them as well.
Old 05-26-2015, 07:57 AM   #6
1976 31' Sovereign
Oswego , Illinois
You do not have to change fuse panel when installing new converter from old unlvolt, only thing that doesn't work is power on light. I don't no of any converter that has power on lite feature. Pur. nite lite plug into 110 outlet you will have power on indicator, also buss type fuses readily avbl. so why go to expense of changing fuse panel as you will very seldom blow a fuse. I changed my univolt to converter many yrs. I ago have blown 1 fuse in 39 yrs owning my AS[50 amp] buss fuse when testing output of converter [probe touched both outputs on converter] only 1 fuse blew no damage. It is simple change over, any questions pm me w/ph.# I can tell you how to change over, and easiest way to remove and replace converter. As for changing fuse panel my theory is if not broken leave it alone.
Old 05-26-2015, 05:07 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The new blade type fuses and fuse block are far superior to the old glass fuses and holder. If you are going to the trouble of changing the converter. Upgrade the fuse block. You won't regret it.
Old 05-27-2015, 07:40 AM   #8
1976 31' Sovereign
Oswego , Illinois
Question converter
Can you explain in detail why blade fuses are better? A fuse is a fuse no matter if glass or blade. Auto manf. went to blade type as smaller and other reasons pertaining to assembly of autos. I stand behind what I stated prev. 1 fuse blown in 39 yrs. and my fault, so in my opinion waste of money and work to change over, but some people always want new things even if not better than old.
Old 05-27-2015, 08:02 AM   #9
1974 Argosy 20
Kooskia , Idaho
Unfortunately the old fuse panels do get just that, old. The spring clips often lose tension and then arcing starts. Same with the riveted connections between the clips and the bars they are attached to.
I don't think that one type is better than the other, but glass fuses are somewhat harder to find now.
I have replaced fuse panels mostly because they are old and often damaged over the years. Electrical parts which were not what I would call top quality to begin with are often just tired at 40 years.
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Converter relocation FrankR Batteries, Univolts, Converters & Inverters 0 07-31-2002 08:30 AM
Converter box floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 10:34 PM
Converter box for into floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 09:49 PM
