Old 08-08-2016, 11:23 AM   #1
2017 30' Flying Cloud
Spotsylvania , Virginia
Constant drain on my batteries
I have a 2015 23FB International and after 18 months of ownership, the batteries are toast. According to when they were installed at the factory the batteries are approximately 2 + years old.
I purchased two new Batteries from Batteries Plus this weekend and installed them in the coach.
I have used Battery Tenders for years to keep the batteries charged in all my toys. After two days of being plugged in the red idiot light is still illuminated. I went to the power converter and pulled every fuse out and the voltage drain didn't stop.
I looked over at the LP leak detector and the green light was on. I pulled the thing out of the wall and cut the positive wire.
I am waiting to see if the Battery Tender light will turn green.
Where is this positive feed coming from for the leak detector so that I may install a switch in the circuit?
Are there any other mysterious 12 volt drains within the coach?
Also, does the switch have to be in the "usage mode" to charge the batteries when plugged into shore power?
KWN306 is offline   Reply With Quote
Old 08-08-2016, 11:56 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yes, the switch needs to be in USE to charge the batteries form shorepower. Some have said their trailer has the subwoofer energized all of the time so that may be another drain. In my trailer only the propane detector is alive with the switch in STORE. But, that can drain the batteries over time in storage.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-08-2016, 12:05 PM   #3
Nowhere , Somewhere
Are there any lights in the storage compartments which could be left on? Don't know if AS have these, my Avion does and I have left one on before.
avionstream is offline   Reply With Quote
Old 08-08-2016, 12:06 PM   #4
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
I have a 2015 27 ft FC. I had to replace my batteries one month after their one year warranty was up. I also replaced the charger/converter. There are a ton of threads about this in the batteries/converters/chargers cation of the forum. Good luck.
Mike
PS. It seems easier to me to physically disconnect your batteries than to cut the wire on your important propane detector.
Caffeinated is offline   Reply With Quote
Old 08-08-2016, 03:19 PM   #5
CLOUDSPLITTER Phone home
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
Also too....
If the radio has a removable faceplate, do it.
I put a switch on the LPG detector...
ID:	268585   Click image for larger version
OOP's
Old 08-08-2016, 03:51 PM   #6
Missouri Valley , Iowa
We have an indicator light on the TV antenna booster in both trailers. It will eventually draw the batteries down, too.
Dan
Farmer Dan is offline   Reply With Quote
Old 08-09-2016, 11:38 AM   #7
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
I concur. Check also if the tongue jack light is ON.
Not sure if you have done this, but why not disconnect all leads going into the trailer so you are left with the parallel connections. Then check to see if the batteries themselves are ok.
Check for water levels on the battery just for kicks.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 08-09-2016, 11:45 AM   #8
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Venice , Florida
Send a message via Skype™ to beachbouy
Parasitic battery drain...Use a battery disconnect switch. I do with a Renogy 100 Watt 12 Volt Solar and always charged and ready to roll.
We drag Mitzi a 2016 International Serenity 30, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 08-09-2016, 11:51 AM   #9
Originally Posted by ROBERT CROSS View Post
Also too....
Bob,
I like what you did, who's switch manufacturer did you use? My LP detector is mounted on a piece of 3/4" veneer particle board and I have been unable to locate a switch that has a long enough neck to fit through the piece of wood.
Kurt
Old 08-09-2016, 11:57 AM   #10
Isn't that what the store / usage switch is for? I have had many RV's, this is my 1st AS and the others always had a marine style big red off/on switch for the batteries and I did not have this issue.
There is really not anywhere to mount (and hide that type/style of a switch) in a 23 FB.
Old 08-09-2016, 11:59 AM   #11
johnkellygreen
johnkellygre's Avatar
1985 25' Sovereign
Lansdowne , Pennsylvania
You could countersink a larger diameter hole from the face plate and use a switch with a longer toggle.
johnkellygre is offline   Reply With Quote
Old 08-09-2016, 12:07 PM   #12
Arnoldter's Avatar
2016 27' International
Indian Trail , North Carolina
I put a battery disconnect switch on the negative terminal. I just flip a switch, when I put in storage. This disconnects everything. I purchase it from AutoZone.
Arnold and Amy Terkel
2016 27FB
2016 Chevy Silverado 1500
Arnoldter is offline   Reply With Quote
Old 08-09-2016, 12:09 PM   #13
2016 23' Flying Cloud
Corpus Christi , Texas
Batteries dead
Yup, had to replace the batteries and converter in our new rig. Have had to replace refrig fan also. Fix door, leak at toilet etc. Lots of repairs to a new product.
2fromtexas is offline   Reply With Quote
Old 08-09-2016, 12:18 PM   #14
Thumbs up
Originally Posted by KWN306 View Post
Bob,
Kurt
Kurt,
A-Zon is your friend.
OOP's
Airstream Daily constant ineruptions LeeJ Forum Admin, News and Member Account Info 2 07-25-2015 05:41 PM
Constant leak beneath the Kitchen 73 31ft Sovereign Advice desperately needed barender Fresh Water Systems 10 05-26-2011 01:15 AM
Constant Hum Aluminumb Batteries, Univolts, Converters & Inverters 8 11-05-2007 12:10 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
