Old 08-09-2016, 01:19 PM   #15
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
Even in the store position there is a parasitic battery drain because the propane leak detector is always on. The constant voltage drop on your batteries will be enough over time they will never recharge... I learned the hardway. Went to a switch, gel batteries and solar... no more problems. Fortunately the Interstate battery distributor gave me a deal on the original batteries. Since they were under warranty ((5 months old) that is how quickly you can kill batteries with parasitic drain)) I went with two sealed AGM Interstate batteries and a top post battery disconnect switch on the negative post to cut the circuit.
Originally Posted by KWN306 View Post
Isn't that what the store / usage switch is for? I have had many RV's, this is my 1st AS and the others always had a marine style big red off/on switch for the batteries and I did not have this issue.
There is really not anywhere to mount (and hide that type/style of a switch) in a 23 FB.
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance shoes, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 08-09-2016, 02:04 PM   #16
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
Also, there is a fan that keeps air moving on your frig., this fan is set to run if the outside temp is over 45', I unhook the fan when I not using the AS.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 08-09-2016, 02:11 PM   #17
Displaced Beach Bum
beachbouy's Avatar
I have never experienced that and living in southern Florida our outside temp is always over 45.
Old 08-09-2016, 02:44 PM   #18
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
The only answer is a battery, solar, converter or inverter (which ever is applicable) disconnect switches like Lew installs. Also, shorted cell in a battery bank will kill the other cells in short order. Residual drains are like germs they are everywhere.
guskmg
Old 08-09-2016, 11:56 PM   #19
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Here us a good thread on parasitic or phantom loads.
http://www.airforums.com/forums/f449...on-140542.html
CruizinDux is offline   Reply With Quote
Old 08-10-2016, 04:51 AM   #20
Long Island , New York
Thanks for this link, Bob, from before we got our FC20 last fall. idroba was certainly a fount of knowledge and a gentleman.
Rest in Peace.
Peter
PS -- edit -- also good to see the following advice, as an answer was not forthcoming in that other recent thread:
Originally Posted by idroba View Post
I also just remove those two jumper wires when I put the rig into winter storage as it is the easiest way to totally disconnect the batteries. Easier than disconnecting either the positive or negative cables and accomplishes the same thing.
OTRA15 is online now   Reply With Quote
Old 08-10-2016, 02:20 PM   #21
CruizinDux's Avatar
Peter, thanks for adding this. "idroba was certainly a fount of knowledge and a gentleman.
Rest in Peace."
An true officer and a gentleman as they say.
Old 08-11-2016, 03:53 PM   #22
2016 30' Classic
Santa Rosa , California
I dont know if your AS has cabinet lights that come on when you open them, but if so, be sure they go off when the cabinet door is shut. I've had to adjust several in our AS to prevent them being constantly on.
Installing a battery terminal disconnect will address all the potential power drains while stored - why add individual switches for the propane detector, etc?
Happy Trails,
Phil
phann is offline   Reply With Quote
Airstream Daily constant ineruptions LeeJ Forum Admin, News and Member Account Info 2 07-25-2015 06:41 PM
Constant leak beneath the Kitchen 73 31ft Sovereign Advice desperately needed barender Fresh Water Systems 10 05-26-2011 02:15 AM
Constant Hum Aluminumb Batteries, Univolts, Converters & Inverters 8 11-05-2007 01:10 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 05:09 PM
