Old 05-26-2019, 07:39 AM   #1
2019 25' International
Providence , Rhode Island
Connectors used on fridge fan?
Anyone know what the square connector types are used to connect the wires?
Mine are clear plastic and square.
Haven't had to work with them in the past and I am changing the fans out with super quite versions.
Would like to use the same connectors if I can source them locally, if not then I'll just use my traditional outdoor connectors.
Anyone know?
Chris
kittmaster is offline   Reply With Quote
Old 05-26-2019, 08:04 AM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I think youre looking for
Utilitech terminal block 0049497 22-10 gauge
White plastic used screws to connect. I found them at Lowes.
No not a great memory Im on a trip and have the box.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 05-26-2019, 08:10 AM   #3
Like this:
https://www.lowes.com/pd/Utilitech-P...tors/999954078
Old 05-26-2019, 08:36 AM   #4
GCinSC2's Avatar
This is the one I have
https://www.lowes.com/pd/Utilitech-Q...tors/999953966
S/OS #001
Old 05-26-2019, 07:13 PM   #5
I found the exact connector....these are pretty cool. Splice multi gauges together and has a lock lever to make changes simple.....
See for yourself:
https://www.amazon.com/221-412-2-Con...s%2C136&sr=8-3
Dometic fridge fan running while fridge is off fclewis Electrical - Systems, Generators, Batteries & Solar 4 10-17-2018 08:30 PM
fridge cooling fan is on but fridge is not running hahnstead Refrigerators 5 06-24-2016 06:34 PM
Video and stereo connectors not used 2005 Safari vintagemike Audio, Video & TV 3 03-28-2016 10:22 AM
240 volt connectors??? gparker Electrical - Systems, Generators, Batteries & Solar 4 07-31-2006 04:57 PM
12vDC wall connectors walter1 Electrical - Systems, Generators, Batteries & Solar 10 09-19-2004 12:53 PM
