Originally Posted by adonh
...Never connect heater to a power converter without a battery in line. Be sure that the heater is connected to a "filtered" (pure DC) circuit of the converter.
Don
Don,
The heater controller is obviously sensitive to "noise" on the DC voltage. Older converters are notorious for poor voltage regulation, which is improved with a battery in the circuit. If you have an older converter, just make sure you always have a battery connected if the converter is powered up.
If you have a new converter, this is less of a problem. You won't find a special "filtered (pure DC)" output on the usual RV converters. I haven't seen one on any converter.
Don't worry about it. There's not much you can do, anyway. Just get the polarity right. BTW, with a modern converter you can probably get away with no battery in the line--they are pretty good--but I wouldn't do it on purpose. If you think about it, there are times when you're plugged in (so the converter is powered up) and you decide to switch out the battery. Oops.
Zep
