Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 02-10-2004, 08:49 AM   #1
ssolid
SSOLID
Profile:  1972 25' Tradewind
Merritt Island , Florida
Connecting to Electricity
Can anyone tell me what size extension cord I need to purcahse to get electricty to my A/S. I have an adapter for the 220 power cord, but my home extension cords are not heavy duty enough (got a spark which was not good). Any other tips on this subject would be greatly appreciated. I am such a greenhorn...
Thank You,
Steve
ssolid is offline   Reply With Quote
Old 02-10-2004, 08:54 AM   #2
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Steve, you don't have a 220 volt power cord. You probably have a 110 30 amp end on your cord. I'm assuming you are probably pluging into a standard household outlet which is either providing 15 or 20 amp service. In that case use a heavy duty cord of equal or better capacity but don't consider running the A/C which may cause you to exceed the capacity of that household circuit.
I'm seriously considering running a 30 amp circuit in the garage this year so I can turn on the A/C while prepping the trailer for an outing.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 02-10-2004, 08:55 AM   #3
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
voltage
To begin with your AS is definitely not 220 volts.
If you are trying to connect it to the 220, you will get big spark.
You need a 30 amp cord from Wal-mart that is made for RVs
It has a three prong plug that is typical of all campground 30 amp/120 volt connections.
You will probably get a little spark when you plug it in, that is becasue your converter is putting a load on the circuit. It is normal.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 02-10-2004, 08:57 AM   #4
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Depends on how long it needs to be.
http://www.pljohnson.com/electrical/...voltdrop.shtml
the above gives the answer in size based on the distance.
Your A/S only uses 120 not 220.
Garry
Old 02-10-2004, 09:27 AM   #5
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Re: voltage
Originally posted by smily
...You need a 30 amp cord from Wal-mart that is made for RVs.
Be extremely careful that whatever you buy is made of at least 10 gauge wire. The wire I saw at Walmart was really thick, and looked like it would light up NYC, but the wire size was only 12 gauge, which is only rated for 20 amps.
Remember, the smaller the wire gauge, the bigger the wire.
Old 02-10-2004, 09:43 AM   #6
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Like Jack, I'll be installing a 30amp circuit. I already have the underground conduit between the hous and the garage....and I picked up the basic parts....just need to have an electrician install it. Also I agree, if you use the cheater, don't use the A/C.
Also, no way your coach is 220v (if it's factory)!
Old 02-10-2004, 11:32 AM   #7
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Exclamation
Your coach, if it is still wired as from the factory, is 110v. If you manage to hook it up to 220, serious damage to the electrical equipment inside the trailer will almost certainly result. There is an adapter for going from the 30 amp plug your trailer most likely has, to a 15 amp (household) outlet, it usually costs a couple of dollars, just don't run the A/C with this, even if you don't pop a circuit breaker, it will starve the compressor, and burn out the motor.
Change is inevitable, except from a vending machine
AIR#2611
Old 02-10-2004, 12:51 PM   #8
ssolid
SSOLID
Thaks to all
Went to wal-mart and got what I needed. Thank you all so much for the education.
Steve
Old 02-10-2004, 12:56 PM   #9
Janet's Husband
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
I would recommend that if you are getting an arc when plugging in, you should probably go to your breaker box and turn off the breakers, plug in your trailer, then turn the breakers on.
I don't know how big your arc is but over time it will cause damage to your plug.
Find out what is causing your arc and correct it. You can hook a clamp on Ammeter on your power cord and see if the draw is equal to what is normally energized when you are plugging in.
To my knowlage extension cords are not rated to make or break a load of any kind. If all is well with your trailers' electrical system, try the breaker trick, your equipment to last a lot longer.
Arc cause power surges at the equipment.
When it comes to extension cords "Bigger is Better" no less than 10awg for a 30 amp circuit on a short cord 25' or less, and that is pushing it in a full load situation. It will heat up at the connectors watch for discoloration and try to keep flamables away from them.
Electrical Safety is worth the extra effort.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 02-10-2004, 01:13 PM   #10
Silvertwinkie
Aluminut
I've been also thinking of getting one of those surge supressors for RVs.
Old 02-10-2004, 05:07 PM   #11
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
arrestors
twink
save your money on a suppressor.
line surges are few and far between. unless your electrical service is directly hit by lightning you are wasting your money.
even if you have a "surge" protector a direct lightning hit will destroy everything including your suppressor! thats what you have insurance for.
in my years at the power company i have only seen one instance where a higher than required voltage was applied to a distrubution line, it was during an ice storm and the system operator reclosed the line 16 times hoping it would hold. we destroyed 30 customers equipment. and paid for every single light bulb, garage door opener, wasing machine, tv, vcr etc.
every single distrubution transformer in america is protected by a lightning arrestor 100 times better than you can buy! they blow to protect your equipment. i know, i have changed out 100's of them!
here is a pic...
john
Name:	dist arrestor.jpg
you call them ferrets, i call them weasels.
Old 02-10-2004, 07:30 PM   #12
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Keep asking SSteve... I'm only halfway to enlightenment and enjoying every visit to this website.
To fill in a few details from past threads:
Walmart 30A cords are not heavy enough gauge. Camping World's 30A cords are 10ga I seem to recall and are the correct item -- http://www.campingworld.com/browse/s...5&skunum=24488
Although mention is made above about your air conditioning -- really really really don't run the A/C on a lower amperage circuit even if you buy an adapter. It will destroy the compressor and cause a big repair bill. Folks have had an electrician wire a dedicated 30A circuit to the garage or wherever if they need to run their A/C at home.
Old 02-10-2004, 07:46 PM   #13
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
30 amp circuit at my garage
I went 20 years with no electricity in my remote garage 100 ft from my house. Getting the Airstream finally gave me the impetus to do something. The power company changing from NSP to Excel also helped. They changed their policy and gave me a separate meter--something they refused when I built and again about 10 years ago. I have a separate 100 amp service to my garage and a dedicated 30 amp outside water repellent boxed outlet for my Airstream. The cord on my Airstream is fairly long and reaches all the way around the back of the trailer to the outlet with length to spare.
I now have a 200 amp general service to the house. A separate 200 amp service for radiant heat in the house and a 100 amp service to the garage. A whopping 500 amps! I wish my cylinder index was as high. :::ugh, ugh, ugh:::
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 02-10-2004, 07:46 PM   #14
Silvertwinkie
Aluminut
You know, the old power cord on my '03 looked much thicker than the one that came with my '04.
Wonder if they still have the same wire inside.
