Well, made a little progress since my original post. the first pic on the left, looks like the feed from the tow vehicle. (I propped the original C channel behind the wires, and it has a hole, that would bring the wires up between the skins from under the trailer). Looks like the Orange wire is the
12v system, and this heads off in the direction of the battery box, to recharge the battery while towing. The green wire with black tracer are the brake/tail/turn/marker lights. I have pinged out the green/black wires, all external lights are now operational.
I should be ready to install the insulation. These wires will be behind the insulation, and future maintenance will be through holes in the exterior skin. The remaining electrical systems (house
12v & 110v) will be on top of the insulation, and accessible via holes in the interior skin.
This pic of the original belly pan is outside up (if still installed it would be outside down, and right side would be left side)
If I recall correctly the square hole in front is a hatch (at the bottom of the pic), would have allowed access between the belly pan and floor, and had a bunch of connections that would have attached the pig tail for tow vehicle connection plug to the trailer system. It looks like there is a 110v wire running the length of the trailer OUTSIDE the belly pan. Can anybody tell me what that wire might have been for ?
