Old 09-18-2006, 08:26 PM   #1
1976 26' Argosy 26
St. Albert , Alberta
Clearance lights get dim?
Quick question: if the clearance lights on the trailer run off the tow vehicle...would adding more clearance light make each one dimmer? Or are they all connected in series?
Thanks a bunch!
Cheers!
Chopper is offline   Reply With Quote
Old 09-18-2006, 08:35 PM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Dim Clearance Lights
Not sure if the lights are connected in series or not. but the number one problem with having dim exterior running lights is usually a poor ground.
Kevin
Old 09-18-2006, 08:54 PM   #3
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Chopper, Unless you add BUNCHES of these lights, and only if your battery and/or altenater are weak, they will not make them get dim.
They are NOT wired in series (remember us talking about a single ground from front to back to which you could connect all your ground wires?).
The most difficult thing you will run up against is pulling wire through the spaces that are full of the pink panther (INSULATION).
Oh, by the way, you might want to make sure the ground between the trailer and the Tow vehicle has good integrity.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 09-18-2006, 10:04 PM   #4
1976 26' Argosy 26
Got it, thanks
Ok, thanks, that's one more question out of the way!
Cheers!
Old 09-25-2006, 03:41 AM   #5
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Here you are again Chopper. Your dimming of the clearance lights stems from bad/weak grounding. In a 12Volt system unless grounding is 100% it will drive you to insanity. it is obvious you are loosing available amperage or have a short which causes excessive draw. Check the available voltage at the line to those lights. "boatdoc"
good luck.
boatdoc is offline   Reply With Quote
Old 09-25-2006, 09:27 AM   #6
1976 26' Argosy 26
Thanks Boatdoc
I've decided to run with the "direct ground" method of running a ground to each of the lights and fixtures then taking all the grounds back to the 7-pin and on to the tow vehicle. Because I'm doing a rebuild that has bunks and beds up on platforms, I can run a conduit on top of the original floor without much problem, then fishtape it up to the fixtures. At least that's the plan.
Cheers!
Old 09-25-2006, 10:37 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
double the wiring, double the work
Cheers!
You don't need to run a separate ground for each and every thing, it will addto the electrical complexity of your coach, and double the potential for wiring problems. If you want your lights to ground properly, you can drill out the rivets holding the housings to the body, and re-rivet them, ensuring good contact for years.
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Rrunning Lights niftypkg Electrical - Systems, Generators, Batteries & Solar 7 08-22-2002 10:30 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
