Old 02-04-2016, 10:20 AM   #1
1968 22' Safari
Tulsa , Oklahoma
Circuit identifier/tester
A few months back, someone posted a reference to a tool that he/she considered a "must have". I can't find it for the life of me.
The tool in question, as I understand it, was a circuit identifier, a somewhat specialized circuit tester. As I understood it, the user would alligator clip a signaling device onto a "where the heck does this go" wire and then use a proximity sensor to locate the other end of the wire. For instance, I might see a wire protruding from the roof in the rear. I could alligator clip the signaling device on there and then wave the sensor about the Central Control panel. When the sensor got close to the end of the wire that had the signaling device attached at the other end, it would sound off.
Does anyone else recall that post or that tool? I want one!
Jay Dunham
splyb is offline   Reply With Quote
Old 02-11-2016, 08:25 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
perhaps:
http://www.airforums.com/forums/f447...er-146488.html
sgschwend is offline   Reply With Quote
Old 02-11-2016, 08:44 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
You're probably looking for something like this: http://www.amazon.com/Fluke-Networks.../dp/B000FTADX0
Called by various names:
• signal tracer
• fox and hound
• tone generator
I use mine almost every day!!
Old 02-12-2016, 09:00 AM   #4
1968 22' Safari
Tulsa , Oklahoma
Done. (If the Lewster recommends it, I buy it.)
Old 02-12-2016, 04:30 PM   #5
lewster's Avatar
Old 02-12-2016, 11:02 PM   #6
2007 22' International CCD
I have a nice old one to go with my 66-block punch down tool and butt set.
And if you know what I'm talking about, you probably know what a 400A card is used for too.
I used to own a complete set of Bell System Plant Practices manuals....
I'm just a pile of old-style tech at times.
Old 02-12-2016, 11:38 PM   #7
Good Governor Circuit Tester JHE Electronics & Connectivity 2 12-07-2013 05:01 AM
Sun Tester EMT 1010-FA 267 Chuckles Mechanics Corner - Engines, Transmission & More... 0 08-27-2010 06:09 AM
TV/Trailer Wiring Tester nickmeloy Brakes & Brake Controllers 1 08-16-2010 09:20 PM
super cheap l.e.d. tester Excella CM Lights - Interior & Exterior 3 05-28-2007 09:35 AM
Great AC tester FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-18-2002 12:52 PM
