Old 02-13-2011, 08:01 AM   #1
2009 25' FB International
Greensboro , North Carolina
Circuit breakers in '09 International 25FB
We seem to have tripped the circuit breaker with overload by plugging in two appliances at the same time. All outlets except one in bedroom do not work. Fridge and TV don't work, either. The Airstream instruction manual is useless (says panel is under dinette when it's actually in the bedroom). At any rate, testing the GFCI doesn't work. When pressing test button, nothing happens. Fuses seem to be OK. Any ideas?
donna01 is offline   Reply With Quote
Old 02-13-2011, 08:12 AM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Donna,
You're gonna get answers from more experienced than me, but testing the GFCI will cause it to trip or disconnect power. It must then be reset to restore power. Are you at home or at a camp? Doesn't hurt to start over from your power connection, make sure all breakers are not tripped and in a mid way position between ON and OFF. To reset, push to off then back to on. Remove all connected loads, try again.
Good luck.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-13-2011, 08:16 AM   #3
2008 25' Safari FB SE
jax , Florida
make sure you turn breakers to off then back on to reset.
the breaker has to be set to off to reset.
happens to us when my wife uses blow drier and forgets to turn off electric heater.
lstrip is offline   Reply With Quote
Old 02-13-2011, 09:55 AM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The breakers are in the same panel as the converter and 12 volt fuses.
Old 02-13-2011, 12:10 PM   #5
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
To reset the GFCI once popped or tested push all the way down first, then up to reset.
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 02-13-2011, 02:23 PM   #6
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Do you have an inverter??
If so check to make sure the inverter breaker (located on the inverter) has not tripped.
Garry
Old 03-13-2011, 02:15 PM   #7
Circuit breaker
Thanks, everyone! It was a Sunday morning and we were stumped! Turns out we blew the circuit breaker and it had to be replaced. With a trip to Home Depot and the help of a fellow Airstreamer, with electrical knowledge, we got it fixed.
2008 International 75th Anniversary - 25ft Frank&Mike 2006 - 2010 International 34 03-31-2011 04:41 PM
International logo? NicheVintage 1965 - 1969 Overlander 0 02-09-2011 09:19 PM
Hot shell on 2006 International hapnlin Electrical - Systems, Generators, Batteries & Solar 1 01-25-2011 07:19 PM
1978 23' Safari International info needed ktmmike1 1974 - 1979 Safari 4 01-19-2011 11:07 AM
2009 Airstream International 27' eBay Watch Airstreams on eBay 0 01-17-2011 09:30 AM
