Old 05-24-2012, 07:21 PM   #1
1986 29' Sovereign
Midvale , Utah
Circuit breakers
Circuit breaker, Just purchased a 1986 Airstream Sovereign 29', I have looked high and low for the circuit breaker, Not abel to find it, Any sugestions ??
Hot Rod Lary is offline   Reply With Quote
Old 05-26-2012, 09:56 AM   #2
richinny's Avatar
2011 34' Classic
i don't know your trailer but try looking inside the closets, and the overhead bins. also look around the water heater area inside and under the sink.
maybe someone with specific info will chime in.
Ricky
Old 05-26-2012, 10:16 AM   #3
Flysoncloud's Avatar
1953 21' Flying Cloud
Wentzville , Missouri
Follow the power wire it will lead you.
I have read about the evils of drinking beer so I quit reading.
Flysoncloud is offline   Reply With Quote
Old 05-26-2012, 10:43 AM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
My trailer has a 120 volt breaker box inside the street side closet, a 12 volt converter and fuse panel under the cooking stove next to the entry door, and a 12 volt towing light fuse panel under the 7-way cover directly under the center front window.
Old 05-29-2012, 12:40 PM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Hot Rod Larry..I have the 84 Sovereign, 29ft..It depends on the floor plan, but..that said, I still think you will find at the floor level outside the closet. Just before you step into the bedroom, look down to the floor on your right hand. Pull the cover open and voila~! The should be a total of 4 circuit breakers switch, including the main circuit breaker..For additional info..the fuse panel is up front under the middle window..Check your fuses..you will have to open the gaucho completely to access it. GOOD LUCK~!!
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
