Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-15-2003, 09:51 PM   #1
drboyd
drboyd's Avatar
Profile:
Checking water in the battery...
...is a major pain in the *** in my Tradewind! It's got a front battery door that folds out and down, but the way my propane tanks sit, I've gotta unbolt them and move the one on that side forward a couple inches to get the door all the way open.
Then, of course, the battery is packed into the box and weighs a ton. Then, when you put it back, the top of the box is warped down, so you've gotta pry it up to get the battery back in.
Seems like a lot of trouble for a battery water check... at least compared to a car.
What's anybody doing about this? Y'all got some magic battery that never needs water I can buy when this one dies?
Old 08-15-2003, 10:37 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
If you want Maintence free then you need to be prepared to spend some $$$. AGM or Gel batteries require no maintence and can be mounted in any position. They are availabel at marine stores or you can ored a optima blue top for your local auto parts store.
Sounds good, huh? The only problem is that proper maintence of a Gel or AGM can require diffrent charging voltages than the univolt may put out. If you have a more intelligent charger you can tell it what kind of battery you have and it will do it right.
I do not remeber the voltages for sure but I think Gel 's were 14.5 charge and 13.5 float????
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 01:12 PM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 09:43 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 01:03 PM
test
