Old 07-19-2016, 06:55 PM   #1
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Checking running lights
My trailer is gutted, starting to put it back together. Working on the electrical. I've got new clearance lights, tail lights, etc, now I would like to check to see how they work. With no other electrical hooked up, no battery, grounds, etc; can I safely plug into my two vehicle to check the running lights? If not, any recommendations on how I check to make sure they work?
Greg
Greg1410 is offline   Reply With Quote
Old 07-19-2016, 11:40 PM   #2
Pygmypoacher's Avatar
Black Diamond , Washington
Greg, buy two 6v lantern batteries and a black and red alligator clip lead. Clip the black to the negative of one battery and the red to the positive of the other battery. Wire the two free pos and neg posts to each other. Clip the red alligator to the pos running light wire and the black to the neg wire (assuming you have all running lights in series) they'll light up if they're working. I've used this same setup to check all my new 12v accessories - even the fans.
Pygmypoacher is offline   Reply With Quote
Old 07-20-2016, 06:00 AM   #3
1976 31' Sovereign
Oswego , Illinois
Why not plug into tow vehicle, if any shorts worse thing would blow fuze in tv, you can also use 12volt batt. alone to check. I use jumper cables in tv to check many 12 volt items, no messing with 6 volt batts. as recommended in above post.
Old 07-20-2016, 06:05 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Plug into your tow vehicle.
Old 07-20-2016, 06:46 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Use a battery charger. Most new chargers will shut down if there is a short or overload. A 12 volt 6 amp charger will work just fine.
Old 07-20-2016, 06:54 AM   #6
1973 23' Safari
1970 27' Overlander
Boerne , Texas
TG - I like the battery charger idea. Can I just hook into the wire at the umbilical cord to check each circuit? My clearance and tail lights are grounded to the shell, so do I clip the negative from the charger to the shell?
Old 07-20-2016, 02:17 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Yes. Connect the red lead of the charger to the circuit (wire) you want to check. You have a choice with the black lead. Connect it to the ground/common wire in the UCord or to a clean spot on the frame.
I would make sure the lights work from both locations to verify the ground/common circuit is complete thru the UCord.
Old 07-20-2016, 02:22 PM   #8
1991 25' Excella
Stanfield , Oregon
Use your tv most battery chargers wont apply power until it can sense voltage for safely reasons.
SpletKay06 is offline   Reply With Quote
Old 07-20-2016, 06:11 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Never had a problem using a battery charger to trouble shoot 12 volt electrical systems.
Old 07-20-2016, 06:19 PM   #10
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
I suggest a 12 volt battery or the two lantern batteries in series with a fuse inline on the positive (+) side. Using a battery charger could make problems for the battery charger. The cord should be wired to the standard;
https://www.etrailer.com/faq-wiring.aspx
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Checking lights GAT Towing, Tow Vehicles & Hitches 2 02-10-2013 07:31 PM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
