Old 01-06-2015, 11:55 AM   #1
sequim , Washington
Charging batteries
when you hook up your generator to charge your batteries, do you hook directly to the batteries or do you simply plug the shore power cable into the generator??
reelfastgreg is offline   Reply With Quote
Old 01-06-2015, 12:13 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Even the OEM converter-charger will do a better job of charging the batteries than the unregulated DC output terminals on most generators. I have a 3-stage converter-charger so it's a pretty good battery charger, I just plug the shore power cable into my generator's AC output.
— David
Batteries not charging while driving wildwoodrver Electrical - Systems, Generators, Batteries & Solar 36 08-22-2008 06:33 PM
Motor Home batteries not charging myfirstrv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 17 06-20-2008 11:58 AM
Charging Auxiliary Batteries COLORADO_CAMPER Batteries, Univolts, Converters & Inverters 9 06-09-2008 11:16 AM
GMC Diesel and charging batteries while towing SRoffe Mechanics Corner - Engines, Transmission & More... 17 09-17-2007 09:28 PM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 03:34 PM
