Old 03-08-2016, 11:31 AM   #1
Opelika , Alabama
Charging AS batteries from tow vehicle connection?
Should this be done or should I have the connection to the tow vehicle bypass everything except brakes and towing lights? I'll probably have solar on the roof too.
racecannon is offline   Reply With Quote
Old 03-08-2016, 11:51 AM   #2
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
There are a lot of dependencies in this scenario, but generally speaking you shouldn't expect to get much charge from your Tow Vehicle umbilical connection to your AS. The quick and dirty explanation is that voltage from your vehicle's alternator drops over distance and as the thickness of wiring carrying it decreases. By the time the juice gets to your AS batteries the voltage probably won't be high enough to charge the batteries.
There are ways around this typical scenario, it just depends on how deep down the rabbit hole you want to go. For example, you could run the proper gauge wire from your vehicle's 12v system back to you AS batteries, or you could do something more inventive like installing an inline voltage booster (check this thread: http://www.airforums.com/forums/f37/...op-130091.html).
trekerboy is offline   Reply With Quote
Old 03-08-2016, 12:22 PM   #3
1974 Argosy 20
Kooskia , Idaho
You can expect a charge current of 4 to 11 amps max, most vehicles I have had and measured ran about 6 amps. My current grand cherokee and front battery AS can run as high as 11 amps.
So, there is something, but not a lot available in most setups. As explained in post #2 above, the charge wire size and length make it difficult to change the situation.
Old 03-08-2016, 01:02 PM   #4
Long Island , New York
What would be the purpose of avoiding the small "free" charge from the tow vehicle, in order to keep the trailer batteries topped up?
If it ain't broken don't fix it . .
OTRA15 is online now   Reply With Quote
Old 03-08-2016, 02:10 PM   #5
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
A charge of 5-11 amps for 8 hours travel is 40-88 amp hours. Can't believe that is not a good idea. But we do not carry a generator and sometimes stop for the night with no hookups. So we like the TV charge. You can build a case that the alternator has a heavier load and therefore may have a shorter life. A replacement alternator can be a bit expensive and that might change your approach. Guess the logic would also shift if solar was installed to keep the bank charged. All a compromise, so build a case, decide what is best for your situation, and implement that plan. And if things change, you can adjust. Pat
Old 03-09-2016, 12:33 PM   #6
1996 25' Excella
Tillsonburg , Ontario
Go with the biggest wiring you can install from the TV battery back to the 7-way on the TV. I ran 10 gauge but others have used 8 and even 6 gauge. From the 7 way plug to the AS everything else is pretty much cast in stone since the umbilical is a standard size. Short runs of under size wiring don't hurt too much. The voltage loss is a combination of total resistances and the oversize wiring in the long run through the TV is important to keeping losses low. My Truck battery easily runs the tongue jack if the umbilical is hooked up with no house battery on board.
If you are using the TV as a charger, it might make sense to upgrade your alternator to deliver more amps. That way you will recover quicker when the house batteries are low.
JCW
JCWDCW is offline   Reply With Quote
Old 03-09-2016, 05:27 PM   #7
2002 25' Classic
Kalama , Washington
Perhaps faulty, but my recollection is that amperage is limited by the most resistive part of its run. Sending lots of amps through heavy gauge only to block them transitioning into light gauge leaves no appreciable increase in amps delivered to the intended destination. Electricians and electrical engineers, beam me some know how on this
nwclassic is offline   Reply With Quote
Old 03-09-2016, 09:36 PM   #8
Opelika , Alabama
My concern would be for the health of the airstream battery bank. I wouldn't want the charging current from the TV to boil off the battery acid, assuming that could even happen.
Old 03-10-2016, 03:34 AM   #9
2005 19' Safari
GLENDALE , AZ
Tow vehicle (TV) alternators have built-in regulators, so there is no need to worry about a TV boiling an Airstream's batteries dry. Otherwise, TVs would be ruining their starter batteries, too.
Old 03-10-2016, 06:04 AM   #10
lewster's Avatar
Naples, FL , Hood River, OR
Lifeline and other battery manufacturers prefer to have the charge line going to a trailer's battery bank further regulated or even disconnected. The voltage from the alternator, which is generally regulated at the alternator is still a single stage continuous voltage.
In the 2011 Sprinter that I use daily, my dash mounted Scan Gauge is set to read system voltage, along with a few other parameters. The voltage never varies from 14.1-14.2VDC.
Over a long duration drive with a trailer in tow, this would also be seen at the trailer's batteries. If you have a higher amperage output to the trailer after increasing the wire gauge to that trailer and you increase the amperage to say 15 amps, (even 11 saw Idroba has stated), you will probably overcharge your batteries at some point.
Example: you have the standard 160 amp/hour Interstate battery bank (80 usable amp/hours at 50% depth of discharge), which is depleted by 50 amp/hours after a night of camping with furnace use. Your TV alternator places 10 amps into your trailer while under way, and you drive for 8 hours that day.
After 5 hours (5 hrs X 10 amps = 50 amp/hours) your batteries are full and should be in float charge of 13.2VDC (approx.). Your alternator will still be placing that 10 amp charge into the batteries for another 3 hours, which will bring them into an overcharge state. The alternator will not recognize this and will still be outputting 14.2VDC @ 10 amps into the batteries for as long as you continue to have the engine running.
The simple answer is to have a battery monitor in the trailer so you know how much charge your batteries require at the start of your day and also know what the charge capacity of your TV is, and you do the math. A switch in the trailer on the charge line (simple to install) will give you the means to shut the charge line when you have filled the batteries.
More complex but better solutions include an automatic charge relay that will sense the battery voltage at the trailer and automatically disconnect when they are full (similar to the BIM that Airstream uses in the Interstate vans, or a unit from Blue Sea Systems) or have solar with a quality 3-stage charge controller. Many boats use systems like these to regulate the engine alternator output to the on-board battery banks while under way.
Ya pays yer money and ya makes yer choice.
Old 03-10-2016, 06:45 AM   #11
Opelika , Alabama
I thought about this but TV's have regulating circuitry between the alternator and the battery. The connection to the trailer is a dumb connection. I think some kind of device like those mentioned by other posters here, would need to be installed in the trailer to shut off the circuit. I could do it myself manually, but I don't think it would be simple enough for my wife to do, and she'd probably be mad at the increase is complexity.
Old 03-10-2016, 07:23 AM   #12
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Sounds kinda like another argument for archaic lead acid wet batteries to me.
Charging my house batteries while I drive without a lot of complication is a great convenience in my book.
Talis gentium ceciderunt.
Old 03-10-2016, 08:35 AM   #13
1996 25' Excella
No!
Resistance is the sum of all the parts. A short piece of 12 gauge wire does not negate the advantage of the larger 8 gauge running the length of the truck. It certainly adds to resistance but only for a short distance so the added resistance is quite small. This can most easily be measured by voltage drop. It I put the volt meter across the small bit of 14 guage wire on the fuse in my charge line, I get non-detectable voltage drop; so I have full voltage where I connect to the charge line. If I put it across the 10 gauge wire running through my truck I will see a volt or two drop. If I had used 8 or 6 gauge I would see less voltage drop.
Part of your recollection is based on fact. If I exceed the amperage capacity of the 14 gauge wire, then it will in fact overheat and probably burn it. But unless I'm somehow able to deliver more than 15 amps the small wire just adds a bit of resistance....probably equal to adding a foot or two of extra length to the heavier 10 gauge (in my truck) charge wire. So yes it is a choke, but not a very big one in the overall scheme of things.
JCW
( Chem. Eng.)
Old 03-10-2016, 08:53 AM   #14
1996 25' Excella
The regulation is built into the Alternator, and is/should be about 13.8 volts max so protected TV battery = Protected House battery (assume both Lead Acid). Actual voltage from the Alternator will depend on TV usage. More load from things like radio and lights will shave the voltage as more amps are drawn, as will outside temperatures, which is why nominal 13.8 from the alternator does not usually boil the TV battery. If the Voltage in the TV charge line creeps up to 13.2 the House battery should be "fully" charged. If it reaches the 13.8 delivered by the Alternator, since the house battery has stopped accepting amps, it starts to boil off water. If you have not been losing water in your TV battery then I would not expect to lose it in the House battery.
That being said; the idea of an auto cut-off makes sense if your TV is or seems to be the reason for overcharging the House battery
JCW
Old 03-10-2016, 09:23 AM   #15
1990 32' Excella
jonesboro , Arkansas
Charging
Saw this in another brand trailer while camping. Not sure of all the logistics. The owner had disconnected the charge wire from inside the trailer with a switch between the onboard system and the batteries. Then he ran a wire back to the trailer and installed an inverter and a small battery charger attached and ran that while towing.seemed to work for him.
joel is offline   Reply With Quote
Old 03-10-2016, 09:24 AM   #16
1974 Argosy 20
Kooskia , Idaho
Just to clarify my statements about TV charge currents. The 11 amps is the maximum I have ever seen. It was measured with my Tri Metric battery monitoring system, and occurred when the batteries were low due to overnight camping and a fair amount of furnace and computer use. It was initial charge, within an hour of towing it dropped to about 4 or 5 amps. As batteries charge their acceptance of current at a given voltage drops off.
This was with a pair of 6 volt golf cart type, flooded cell batteries in series mounted in the battery box of my 2014 FC 20, which is at the front of the trailer. TV is a 2102 Jeep Grand Cherokee.
When the same TV is connected to my '74 Argosy, also with golf cart flooded cell batteries, but located near the wheel well, and connected with the original Argosy charge wiring, I have never seen over 6 amps charge current, tapering to about 3 to 4 amps.
The TV charge can be a little additional charge benefit with conventional flooded cell batteries. But it is not much considering actual towing hours. I have never had any other type batteries and can make no statements about them.
BTW, even with the towing I do, my Tri Metric meter seldom if ever shows a 100% charge after towing the average daily milage I do, which is generally in the 100 to 250 mile range. I generally seem to run in the 90 to 92% range maximum when out camping. Those last few amp hours are very difficult to replace with anything other than a 3 stage converter/charger running for 24 to 48 hours on it's last stage.
In general, I run my conventional flooded cell golf cart batteries in the 50 to 90% range of charge when out camping. Once in a while they drop to 40% but not often. My batteries have lasted in the 8 to 9 year range. That is hard to say actually, but my Argosy is on it's second set of golf cart type batteries, and I installed the first set about 2002 I believe. They we're replaced about 2010 or 2011 I think. My 2014 20' FC had it's original batteries replaced (not defective, just wanted to put GC types in) after one year, so in June of 2014. The delivery date was June 2013. So, I have not had them in very long yet.
Old 03-19-2016, 08:40 AM   #17
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
In other thread battery management systems were discussed, which is a single board that regulates and protects the battery and the battery loads. Sounds like one of these would be a good idea for this method of charging. The user could run a 6 gauge wire and even upgrade the alternator and have a way to safely and rapidly (if desired) recharge their AS battery bank.
Most diesel tow vehicles have "larger" alternators to support automatic glow plug circuit and twin batteries. Those users already have the alternator.
sgschwend is offline   Reply With Quote
Charging AGM Batteries via Tow Vehicle Charge Wire gtbzz85 Electrical - Systems, Generators, Batteries & Solar 5 10-06-2012 03:20 PM
Charging Airstream batteries from tow vehicle Jammer Batteries, Univolts, Converters & Inverters 18 10-09-2011 09:28 AM
Tow vehicle charging batteries safari 28 Batteries, Univolts, Converters & Inverters 25 11-15-2009 10:28 PM
Charging the batteries using tow vehicle bci 2006 - 2010 Classic (all lengths) 22 06-09-2008 09:57 PM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 02:34 PM
