Old 03-10-2016, 09:23 AM   #15
1990 32' Excella
jonesboro , Arkansas
Charging
Saw this in another brand trailer while camping. Not sure of all the logistics. The owner had disconnected the charge wire from inside the trailer with a switch between the onboard system and the batteries. Then he ran a wire back to the trailer and installed an inverter and a small battery charger attached and ran that while towing.seemed to work for him.
joel is offline   Reply With Quote
Old 03-10-2016, 09:24 AM   #16
1974 Argosy 20
Kooskia , Idaho
Just to clarify my statements about TV charge currents. The 11 amps is the maximum I have ever seen. It was measured with my Tri Metric battery monitoring system, and occurred when the batteries were low due to overnight camping and a fair amount of furnace and computer use. It was initial charge, within an hour of towing it dropped to about 4 or 5 amps. As batteries charge their acceptance of current at a given voltage drops off.
This was with a pair of 6 volt golf cart type, flooded cell batteries in series mounted in the battery box of my 2014 FC 20, which is at the front of the trailer. TV is a 2102 Jeep Grand Cherokee.
When the same TV is connected to my '74 Argosy, also with golf cart flooded cell batteries, but located near the wheel well, and connected with the original Argosy charge wiring, I have never seen over 6 amps charge current, tapering to about 3 to 4 amps.
The TV charge can be a little additional charge benefit with conventional flooded cell batteries. But it is not much considering actual towing hours. I have never had any other type batteries and can make no statements about them.
BTW, even with the towing I do, my Tri Metric meter seldom if ever shows a 100% charge after towing the average daily milage I do, which is generally in the 100 to 250 mile range. I generally seem to run in the 90 to 92% range maximum when out camping. Those last few amp hours are very difficult to replace with anything other than a 3 stage converter/charger running for 24 to 48 hours on it's last stage.
In general, I run my conventional flooded cell golf cart batteries in the 50 to 90% range of charge when out camping. Once in a while they drop to 40% but not often. My batteries have lasted in the 8 to 9 year range. That is hard to say actually, but my Argosy is on it's second set of golf cart type batteries, and I installed the first set about 2002 I believe. They we're replaced about 2010 or 2011 I think. My 2014 20' FC had it's original batteries replaced (not defective, just wanted to put GC types in) after one year, so in June of 2014. The delivery date was June 2013. So, I have not had them in very long yet.
Old 03-19-2016, 08:40 AM   #17
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
In other thread battery management systems were discussed, which is a single board that regulates and protects the battery and the battery loads. Sounds like one of these would be a good idea for this method of charging. The user could run a 6 gauge wire and even upgrade the alternator and have a way to safely and rapidly (if desired) recharge their AS battery bank.
Most diesel tow vehicles have "larger" alternators to support automatic glow plug circuit and twin batteries. Those users already have the alternator.
sgschwend is offline   Reply With Quote
Charging AGM Batteries via Tow Vehicle Charge Wire gtbzz85 Electrical - Systems, Generators, Batteries & Solar 5 10-06-2012 03:20 PM
Charging Airstream batteries from tow vehicle Jammer Batteries, Univolts, Converters & Inverters 18 10-09-2011 09:28 AM
Tow vehicle charging batteries safari 28 Batteries, Univolts, Converters & Inverters 25 11-15-2009 10:28 PM
Charging the batteries using tow vehicle bci 2006 - 2010 Classic (all lengths) 22 06-09-2008 09:57 PM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 02:34 PM
