Old 06-15-2006, 11:35 AM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Charging 12V using TV and jumper cables?
What is the argument against using the TV and jumper cables to top off the 12V every few days when boondocking? I'm sure it would end in plague, pestulance, and bad karma, and I am sure the engineers are against it; what I dont know is why. Thanks
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 06-15-2006, 12:31 PM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I'm no engineer, but one (probably obvious) issue is the enormous amount of "energy" you'd be expending to do something that proportionately takes a very small amount of "energy" (charging a 12v battery) - like using a firehose to get a drink of water.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 06-15-2006, 12:49 PM   #3
Toasty's Dad's Avatar
2004 16' International CCD
Cincinnati , Ohio
i'm probably cornfused about the proposition, but i read it as:
* hook one end of jumper cables to TV battery.
* hook other end of jumper cables to AS battery.
* a) wait OR
b) start engine and wait
so if i just do "a" and wait, i risk transferring so much energy from the TV battery that i can't start my TV, thus extending my boondock indefinitely.
but if i just do "b" and wait, i don't need the jumper cables (at least on my AS), cause the alternator can charge the AS battery through the umbilical cord. with or without jumper cables, i've just turned my TV is just a spectacularly inefficient generator.
both sound unappetizing to me.
but then i've probably misinterpreted the proposition entirely, so
if so,
ignore me.
jon
btw, totally LOVE your Tradewind!
Toasty's Dad is offline   Reply With Quote
Old 06-15-2006, 12:54 PM   #4
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Inefficient for sure...
Im sure it would be inefficent. I was thinking using the cables might transfer the juice a bit faster what with the increased cable thickness and all. Im just wondering if it would be a workable stop-gap untill I can go the $1K for a generator.
Rodney
and the
My Blog
Old 06-15-2006, 01:38 PM   #5
Cincinnati , Ohio
oh, i see what you're saying!
at the risk of really making a fool of myself, i'll put on my dirtball EE hat, and do an undoubtedly flawed analysis.
4 ga wire, commonly used in jumper cables, has a resistance of .000292 ohms per foot, according to some chart i found on the web. it's so low, that i'll happily assume that it's zero, even over a 12-foot length.
the trailer cord could be as thin as 16 ga, which at .00473 ohms per foot, comes out to .057 ohms in a 12-foot run.
now, assuming alternator output of 13.7 volts, a 50% discharged house battery at 12.5 volts, and a charging rate of 10 Amps (which is perhaps a little optimistic given my experience), the battery's internal resistance is (at least initially) .12 ohms. i'm using our magic jumpers with 0 resistance here.
ok, so now i take off the jumpers, hook up the umbilical, and i've got my trailer cable with a resistance of .057 ohms in series with the battery at .12 ohms.
Charge rate drops to around 6.7 Amps, and nearly 1/3 of the power I'm transferring is expended heating up the wire.
i'll therefore conclude that using the jumper cables is a boffo idea.
now, a real EE can come along and destroy me....
i'm bent down with my head on the block....
jon
Old 06-15-2006, 01:46 PM   #6
_
hi dad and disarray.....
great post toasty....
sure hope to camp with toasty's family again and soon......
you nailed 'em...
understand the need for stopgap charging of the coach battery rodney....
issues i imagine....
-how many amps does your alternator produce at idle?
-without the coach to control charging the battery, will it boil?
-how often will you need to add water?
-might it leak adding insult to disarray?
-what will it do to the life of the truck charging parts?
how about a stationary cycle at the campsite..
that charges the battery while you pedal..
think of the legs you will grow!
or here's another idea....
how about getting 2 coach batteries....
and put one inside the truck so it is charging when ever you drive around and without completely wasting fuel...
since driving is gonna happen anyway?
or get one of those little tiny trick charge solar things....and hook it up to the spare coach battery.....it might add a few amps....or not.
or take the spare coach battery to work
and juice it in the office using instutional power.....
not unlike borrowing a roll of toilet paper...
which i never did during the lean years....
of campus life....
no sir...
cheers
2air'
Old 06-15-2006, 02:04 PM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
since driving is gonna happen anyway...........
cheers
2air'
Thats an interesting idea. I really just need to be sure I can keep the fridge going and the laptop in business if I persue the idea of doing my writing out west next month instead of staying here in southern Illinois
Rodney
and the
My Blog
Old 06-15-2006, 02:25 PM   #8
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
From my 9100 Intellicharger "cheat sheet":
55 Amp Intellipower 9100 Converter using a fully discharged 125 amp hour battery and taking it to 100%.
Boost Mode takes about 18 hours
Normal Mode takes about 78 hours
Storage Mode takes about 105 hours
I am reading this off of a charge curve chart.
I do not think you would accomplish much by trying to charge off of jumper cables, unless you want to run your tv all day long.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-15-2006, 02:59 PM   #9
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I keep 2 deep cycle batteries in a box on the back of the truck. They can be hooked up to the truck for charging, when out touring around. When back at the trailer they can be pluged in, by way of #4 wire, to the trailer. This has worked for years for us, in campgrounds like Ocala Forest with no electric. We can stay as long as we like and have charged batteries all the time. Much cheaper then solar or generators as we already have the truck.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 06-15-2006, 04:06 PM   #10
AZstreamin's Avatar
2005 30' Safari
Chandler , Arizona
Yet another idea
Sell some crap on eBay to fund the purchase of a generator.
"Ones man's trash is another man's treasure"
AZstreamin.
AZstreamin is offline   Reply With Quote
Old 06-15-2006, 05:36 PM   #11
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
jon
I agree with what he says - I don't understand but that usually means the other guy is right.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 06-15-2006, 06:03 PM   #12
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can hook up jumper cables to do this, but, as when I was learning nuclear engineering, it is an expensive way to boil water. A modern vehicle's charging system is designed to keep a fully charged battery fully charged, not charge a discharged one. Newer vehicles have high draw loads on the tow vehicle all the time, and alternators, even 135 amp ones, will overheat from the effort of trying to charge the dead trailer battery while supplying the power needs of the tow vehicle, necessitating an early replacement of the (several hundred dollar) alternator. Getting an alternator replaced on , for example, a 2004 Suburban could cost as much as $350, and for another $250, you could buy a new Honda E1000 to charge the battery on the coach, and use a gallon of gas a day doing it.
You can probably charge the trailer battery several times, and get away with it, but eventually the law of averages will catch up with you, probably at the most inopportune time.
Old 06-15-2006, 06:17 PM   #13
1976 25' Caravanner
Campton , New Hampshire
I use to do the same thing with my old pop-up . The only trouble I had was when I thought I would be smart and keep the batteries charged between camping trips . Dry cells don't like consant charge like a vehicle battery , they will get fried if you leave them hooked up for a week or two.
ticki2 is offline   Reply With Quote
Old 06-16-2006, 12:29 AM   #14
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Rodney,
I would not do it. I recently picked up a Honda EU1000 (1 month old with 2 hours of run time) for $500. I use it to charge my battery when I am out for several days.
Richard
12v
External Antenae Connection Raptorrider2001 1999 Safari 9 01-12-2003 10:02 PM
