Old 07-10-2009, 08:44 PM   #1
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
Charger questions from a newbie
okay, my 85 excella has a hummer charger. are new(er) chargers (replacements) more efficient? quieter? as robust as what AS put in their 85's?
Has anyone relocated their hummer outside of the AS? seems fairly straight-forward to me to locate the dang thang on the tongue. Watertight enclosure for sure, with ventilation, but that would get rid of the hum and heat.
what say you veterans?
wmarsha is offline   Reply With Quote
Old 07-10-2009, 09:08 PM   #2
73Overlander's Avatar
Centralia , Washington
This spring I replaced my Univolt with an Inteli Power 9200 with Charge Wizard.
Perfect silence.
Cameron Bailey
1973 Overlander
Washington Unit, VAC
www.cameron-bailey.com
73Overlander is offline   Reply With Quote
Old 07-12-2009, 12:59 PM   #3
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
i would have a problem with putting a 120vac circuit on the tongue , gfi would be nessesary, also would be prone to tripping. could run wiring under front and then up into coach? easier to seal.converter would be difficult to protect and still vent,a lot of water and debris in transit. most converters won't tolerate the moisture.
crestonrv is offline   Reply With Quote
Old 07-12-2009, 01:45 PM   #4
Streamer Jabe
Jabreyd13's Avatar
1978 31' Excella 500
Edmond , Oklahoma
I just purchased the new Inteli-Power 9245C, and am now wondering what kind of fuse panel to look for on ebay? Any model numbers or suggestions?
Jabreyd13 is offline   Reply With Quote
newbie questions LeisureTime Our Community 14 07-20-2008 02:56 PM
Inverter / Charger Newbie nbk3ad2 Electrical - Systems, Generators, Batteries & Solar 22 02-02-2007 09:23 AM
A newbie with questions ciquing Member Introductions 12 11-17-2006 01:00 PM
Newbie Has Questions LowellN General Repair Forum 6 10-07-2004 06:45 PM
Newbie with questions Tin Hut Axles 11 08-21-2003 06:10 PM
