Okay, I just hooked the radio back up that was under the Control Center in the front of the trailer. It was included with the trailer from the original owner(3 years ago), but I never took the time to hook it up. Well it works and sounds great, however, when I unplugged the 120 volt 30 amp plug from shore power, my
12 volt power didn't kick in. Huuuuummm? Well I dinked around and pulled the 50 amp fuse (on the wall next to the univolt) on the negative side out and tested it and it was fine, but when I put if back in, walla, my
12 volt system was back. Weird???? Well I thought let's see that again, so i plugged the 120 volt line back in and everything was normal, then I unplugged the 120 volt line and my
12 volt disappeared again! So I pulled the 50 amp fuse out and put it right back in and everything worked! Soooooooooooooooooooo.
Any ideas on what is taking place here? Should I assume there is a problem with the Radio, should I disconnect it again and see if my 12 volt works normally. If at this point my 12 volt works normally, what do I do about the Radio wiring????
Help!!! I can sure do without the Radio, but it would be nice to have since there is a spot for it and there are already built in speakers.
Thanks in advance for any insight into this wiring problem!
