Old 06-26-2016, 07:45 AM   #1
2006 25' Safari SS SE
LINCOLN , Nebraska
Changing Thermostats for furnace
I have a 2006 Safari SS with the original wall furnace thermostat. I would like to change it to one that is much easier to read. I bought a White-Rodgers 80 Series Standard Single Stage Digital Non-Programmable Thermostat (New) at a garage sale. Is there any problem with using this is my Airstream?? It says Millivolt Compatible on the package and Next Generation Microprocessor. Rating is 0 to 30 VAC, 50/60 Hz or D.C. 0.05 to 1.0 Amps (load per terminal). Thanks for your help!!
MissingLink5 is offline   Reply With Quote
Old 06-26-2016, 10:15 AM   #2
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
The Dometic thermostat in our trailer has a feature I've never seen in a home thermostat... two modes of heat. If you have a heat pump setting on your AC and a propane furnace I'm not sure a standard home thermostat will offer you features to choose and operate one versus the other. Ditto if you happen to have two AC units running off a single thermostat.
GammaDog is offline   Reply With Quote
Old 06-26-2016, 06:30 PM   #3
LINCOLN , Nebraska
My present thermostat only operates my furnace and it is not a heat pump. The Air Conditioner is a ceiling unit and has its own controls on the ceiling. Therefore, I wouldn't think there would be any special features that would make this incompatible unless it would be the digital readout but it runs on battery power??
WANTED: Magic Chef Oven Thermostats walter1 Stoves, Ovens & Microwaves 10 07-18-2014 05:58 PM
thermostats camsoldman 1984 -1986 Excella 4 02-18-2014 01:38 PM
thermostats Mikebreen Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-08-2010 06:51 AM
Thermostats Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 23 12-31-2008 06:57 AM
why Two Thermostats? ALANSD Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-09-2006 06:11 AM
