Old 10-05-2017, 08:19 PM   #1
2016 22' Sport
Wichita , Kansas
Changing out converter to an inverter/converter combo
I have a 2016 Bambi Sport, 22'FB. I have purchased a 200 watt portable Zamp solar panel. It is working GREAT for DC stuff. However, I want to install a inverter so my AC outlets will work off my batteries. Going to get a Xantrex product but wonder if I should just get an inverter or a inverter/converter combo. What's involved in the change out. And by the way I am a novice so will having a solar dealer here in Wichita put this in!
Aaron-Laura is offline   Reply With Quote
Old 10-05-2017, 08:30 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Just so you know there are many different types of inverters out there; Modified sine wave, sine wave, pure sine wave, square wave..........and you get what you pay for, big time.
I would look up reliability of any inverter and its manufacturers reputation BEFORE you purchase as many of these companies use off shore components.
Also realize that the amount of battery storage needed to power an inverter for 110v is HUGE! Turning on a microwave will kaput your batter power in no time.
Ganging an inverter with a converter is functionally a good thing to do, but remember this.........if one side goes kaput, and you have to get it fixed; you have no power at all. Also a Power Dynamics converter is cheap, cheap, cheap, compared to an inverter/converter.
You need to talk to Lewster before purchasing any components.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 10-05-2017, 08:37 PM   #3
1995 30' Excella
Harper Woods , Michigan
What 120VAC device do you have in mind? A device that draws only 120 watts would 10amps for the device, plus whatever losses that would be added by the inverter. So running a 120VAC device for any significant period might deplete your batteries quickly. Maybe you should consider an inverter generator - they're lighter in weight and run relatively quietly.
This looks like a good deal: https://www.autoaccessoriesgarage.co...able-Generator
Bob Blarney is offline   Reply With Quote
Old 10-06-2017, 03:10 PM   #4
2016 22' Sport
Wichita , Kansas
We will only using the outlets, primarily for laptop, small floor fan, occasional hair dryer or curling iron. NO AC or Microwave. We use DC to charge phones, iPads, cameras. Aaron
Old 10-06-2017, 09:11 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Going to need Pure Sine wave for the electronics if you decide to power them, and you do realize that a hair dryer and curling iron use as much electricity as a microwave.....1500 watts usually.
Old 10-06-2017, 10:21 PM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Best guess is that you will run a hundred watts into the inverter even doing the sort of small stuff you describe. Inverters are not very efficient running light loads. Rough guess is you are in the 10A range as a result. Eight hours of run time will hit 80AH. That's at the "stop using" point on your batteries.
A 200W pannel will give you a practical max of about 160W. If you get that for an effective 8 hours a day, you are doing better than most (full sun in June ...). Solar converter is 80 to 90% efficient. That takes 160W to 140 or so. At 13.7V into the battery, you get about 10A max. In a day, you get about 80 AH.
Now, your hair dryer likely pulls 1800W. That's about 170A off of your battery. In 30 minutes, it will flatten the battery if you do nothing else that day. The battery is less efficient
at that level of current. Three minutes of hair dryer takes away one of your eight hours of "low power stuff".
Bottom line is you don't have any margin. Ideally you would like to have a one day charge that will keep you running for two days (like when there are clouds). You would need about 2X the solar to get that done.
Old 10-07-2017, 10:27 AM   #7
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
We're happy with our Magnum MMS1012-G pure sine wave, 1000W inverter charger. Cost is about $850. We added the ME-ARC50 Advanced Remote Control and the Battery Monitor Kit.
The MMS1012-G has the correct charging profiles for AGM and even lithium batteries. We use it with our Lifeline GPL-31T AGM batteries.
We only use the inverter for little things - laptop charger, small TV, etc. We do not use an inverter for A/C, cooking, hair dryer, curling iron, etc.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 10-07-2017, 06:43 PM   #8
1988 32' Excella
Robbinsville , New Jersey
My parents trailer has an inverter/charger and the way the previous owner had it wired it "tries" to power the entire trailer. I hate that setup since if the air conditioner is on and the power goes out it will try to power it and overload, reset and overload........................... until the AC is turned off, the power comes back on, the battery dies or something fails. Really bad if you go out for a couple hours and the power goes out.
Old 10-07-2017, 07:09 PM   #9
Half a Rivet Short
Hi
Inverter / chargers don't *have* to run all the 120V outlets. With any inverter, it's generally better to think a bit about what you do or do not want to route to the inverter via the transfer switch. Transfer switches are an independent choice. Not all inverter / chargers have them. Some inverters have them built in ... It's a separate choice.
Old 10-08-2017, 06:18 PM   #10
2015 22' FB Sport
Wethersfield , Connecticut
I installed a 1000 watt (2000 watt peak) pure sun wave inverter under the bed with one outlet on the wall beneath the bed. With the 100 ah Li Ion battery it works fine to run the TV and charge the tooth brush etc. the 100 watt solar panel has been adequate during our weeklong trips.
TinkersToy is offline   Reply With Quote
Old 10-09-2017, 09:18 AM   #11
Half a Rivet Short
Hi
Note to those reading along:
1KW inverter will pull about 150A off the battery. At 2KW peak, it will run 300A. .... even for lithiums, that's not a good idea on a 100AH battery. Peak currents should be less that capacity. Will it nuke the battery instantly? nope. It will wear it out pretty fast.
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 11:50 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 02:48 PM
Changing the converter Skee75 2011 - 2015 International 8 04-11-2015 05:52 AM
Changing the Twins out Fun-Lovin General Interior Topics 5 09-25-2003 03:47 PM
Changing out the Black water tank AccessMaster Airstream Motorhome Forums 8 08-30-2003 09:03 AM
