Old 01-12-2007, 01:15 PM   #1
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Ceiling light bulb change question
This new 23 Safari has the SE/LS upgrades but the manual doesn't address them.
The question is, how do you open light fixture to replace a burned out bulb in the inset ceiling lights, the same ones that come standard in the CCDs? The manual only addresses the standard Safari lights.
Thought I'd just ask rather than start digging around with a knife or screwdriver.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 01-13-2007, 08:37 AM   #2
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Still looking for a response to this question.
Antique Pedaler
Old 01-13-2007, 09:15 AM   #3
jglabrown's Avatar
2005 16' International CCD
2009 23' International
Bainbridge Island , Washington
Try searching "5 Watt bulbs in CCD". There are several threads devoted to changing out the recessed lights.
Larry
jglabrown is offline   Reply With Quote
Old 01-13-2007, 09:32 AM   #4
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Thanks, Jglabrown, that worked.
Antique Pedaler
Pilot light in Frig niftypkg Refrigerators 9 04-10-2005 12:04 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Electric Brake Question. 68 Suburban Brakes & Brake Controllers 7 10-11-2002 09:14 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
