Old 03-29-2011, 06:34 PM   #1
2010 23' FB Flying Cloud
Smithville , Texas
Carbon Monoxide Alarm
OK, I give up. How do you get the carbon monoxide alarm open to change the battery.
Yes, I see the arrow that says which way to twist it, but with all my strength I cannot budge the damned thing.
Am I missing something? And please don't say I'm missing my brain. I'm embarrassed enough to ask this question.
The brand is Costar and I find no help on their web site.
Matt & Virginia Kline
2010 FC23FB
2016 F-350 6.7 Diesel (Overkill and loving it)
Matt Kline is offline   Reply With Quote
Old 03-29-2011, 06:37 PM   #2
x
XXXX , XXXX
Sometimes there is a locking pin on the side that must be removed first.
wasagachris is offline   Reply With Quote
Old 03-29-2011, 06:45 PM   #3
Smithville , Texas
Sure enough
THANK YOU THANK YOU THANK YOU.
Yes, there was a pin on top that I pried out with a screw driver. How in the world was I supposed to know that?
2010 FC23FB
Old 03-29-2011, 06:49 PM   #4
x
XXXX , XXXX
ESP maybe or if the owners packet had instructions for the CO detector. LOL.
Old 04-20-2014, 09:40 AM   #5
2010 16' International
kittery , Maine
I too was going nuts trying to figure out how to remove the Costar. Gave it lots of muscle, to the point at which I thought bad things would happen to my hands if and when it broke apart, so I thought I'd check the forums, and found this thread.
Going back to look for that locking tab. Thanks!
I was getting tired of hearing it beep all winter long. Spring is finally here, just opened up the trailer for the first time in months.
amm3824 is offline   Reply With Quote
Old 04-29-2014, 02:06 PM   #6
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
How do we disconnect the CO detector when storeing the trailer, turn off battery sw at door and CO green light stills is on, so the power drain is there?
Julie-Bob is offline   Reply With Quote
Old 04-29-2014, 02:09 PM   #7
Gainesville , Florida
You must be looking at the lp gas detecter which is hot wired to the battery. The co detector usually has a nine volt battery in it, at least on the older trailers. Jim
Old 04-30-2014, 08:17 AM   #8
Julie-Bob's Avatar
2009 25' FB Classic
Will look hard at it for the battery if installed, the trailer is a 2009. If hard wired to battery. That means that I have to disconnect to stop the drain. However that stops the battery charging while I have it plug in while in storage.
Old 04-30-2014, 08:21 AM   #9
dznf0g's Avatar
Oswego , Illinois
It is code for the manufacturer for the LP detector to be on anytime batteries are in the unit or it is plugged into shore power. That being said, I moved my power feed wire for the detector to the downstream side of the manual cutoff switch so when the unit is in storage with a 15 watt solar panel, I can keep up with drain and keep the batts topped off.
-Rich-
Old 04-30-2014, 08:45 AM   #10
aftermath's Avatar
Spokane , Washington
If you have it plugged in while in storage, why are you concerned about a small drain?
I store mine where I can't hook up so I remove the batteries, bring them home and put them in the basement. It is a hassle for sure. I wish I could plug in and nor worry.
aftermath is offline   Reply With Quote
Old 04-30-2014, 10:07 AM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
I removed the propane detector and placed it in the trash. This has solved the battery drain problem as well as the false alarm problem.
A fact to consider is that, if disconnected from power from a period of weeks or longer, it will take several hours after being reconnected for a propane detector to stop alarming as it takes this long for the dust to burn off the sensing element.
The CO detector is another matter as they make a difference for safety.
Also, perhaps off topic, I have replaced my smoke alarm with a higher quality photoelectric one, and have fewer false alarms while cooking.
Old 04-30-2014, 11:39 AM   #12
You do not need a propane detecter? I prefer to have one! Jim
Old 04-30-2014, 12:19 PM   #13
Wise Elder
Jammer's Avatar
2010 30' Classic
In the absence of any report ever of an RV burning or exploding while occupied as a result of a propane leak inside the coach, I don't consider them to solve any problem I actually have.
They make sense on boats, where propane explosions are a serious problem.
Old 04-30-2014, 01:14 PM   #14
I would rather be warned if the trailer filled up with propane than wait until I am breathing it all in. Ever get the chance to breathe in any amount of propane!? It is poison. I am not as worried about an explosion as I am about breathing it. Jim
Ignitor Carbon, Poor Heat linc54 Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-30-2011 06:09 PM
