Old 06-21-2013, 06:07 AM   #15
1987 32' Excella
fulton , Missouri
ok thank you I know what to look for and have found it know how do I go about finding if it works are not?
stuart mott is offline   Reply With Quote
Old 06-21-2013, 08:37 AM   #16
1987 32' Excella
fulton , Missouri
found
i found it the light is green what does that tell me bad battery?
Old 06-21-2013, 08:44 AM   #17
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Perhaps just a fuse.
Follow the large gauge wires from the converter box to the fuse panel. There should be old-style glass fuses that tie power from the converter into the fuse panel. These fuses will be in the panel.
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-21-2013, 01:16 PM   #18
1987 32' Excella
fulton , Missouri
i really foundit
i lefted up the couch and there it is green lie and fan running it looks new it is IOTA DSL 55/iq4 is this new and i can'tget the fuse out
Old 06-21-2013, 01:28 PM   #19
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It's definitely much newer than your trailer, and it's a good converter.
The Iota DLS manual says in a steady on state means the charger is in "float" mode, but it doesn't say what that light should do if the converter isn't connected to batteries, perhaps it would "float" then as well.
Have a look at the manual (linked above) and see if that helps. It mentions fuses installed on the converter itself to protect from reverse polarity and perhaps a short.
David
silverhilton :: 1986 Airstream Excella silverhilton Airstream Registry Discussions 2 10-16-2011 11:01 PM
1986 Excella for sale- PA PA BAMBI II 1984 -1986 Excella 2 09-08-2011 07:02 AM
Amorosa :: 1986 Airstream Excella kellywood Airstream Registry Discussions 0 08-19-2011 09:32 AM
Exterior door lock replacement 1986 Excella kellywood Doors & Locks 3 07-25-2011 07:34 AM
1986 airstream excella 31ft eBay Watch Airstreams on eBay 0 06-14-2011 03:40 PM
