Old 05-14-2007, 01:45 PM   #1
Dan
djfrantic's Avatar
2013 25' FB International
Altadena , California
Can someone ID this switch?
I have a 2006 19' Bambi Int'l CCD and I have a mystery switch that I cannot ID. Nor can the dealer who I bought it from. This switch sits to the left of the door entrance above the fire extinguisher and I have no idea what it is for...when we are out camping I keep the switch up...and the light in the switch is on and bright red...if I turn it off then the light glows a softer red...but it doesn't appear to DO anything...does anyone know what it does?
Here is a link to the pic:
mystery switch on Flickr - Photo Sharing!
Thanks for your help!
Name:	mystery switch.jpg
djfrantic is offline   Reply With Quote
Old 05-14-2007, 02:03 PM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
It Makes Time Travel Possible
Flux Capacitor Exciter
klattu is offline   Reply With Quote
Old 05-14-2007, 02:19 PM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Suspect this is the refrigerator fan switch. Have a 2007 20' Safari and mine is located just inside the door on the left side however mine is labeled as to what it is. If this isn't the answer I don't have a clue.
Al - K4GLU is offline   Reply With Quote
Old 05-14-2007, 02:47 PM   #4
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I would also say it is the refrigerator fan switch. It's exactly where mine is in my 2005 Bambi. The fan is thermostatically controlled and won't switch on unless it reaches a preset temperature in the reefer compartment.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 05-14-2007, 02:52 PM   #5
Dan
djfrantic's Avatar
addendum to original post
I forgot to mention that I have a solar panel on top....I don't think that the switch is related but I thought maybe I should add this info. I traced the solar wiring harness from the roof through the closet and down into the area near the fresh water storage tank where the control module is mounted. From there it goes directly to the batteries and no where near the mystery switch.
Because this is an 06, the FCE (or flux capacitor excitor) was replaced by an internal Positron Thermal Conductor or PTC which is slightly more energy efficient and attractve as well. But thanks for that anyway.
Old 05-14-2007, 03:52 PM   #6
On the road , again...
Try contacting Jackson Center. I'm sure they will know what it is.
rebfa is offline   Reply With Quote
Old 05-14-2007, 04:05 PM   #7
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
That switch is most definitely the refer fan switch. As SilverRanger noted, it's wired to a thermostatic switch, so unless the refer is fired up the switch will have no effect.
To check it for yourself, fire up your refer for an hour or so. Once the plumbing is warmed up enough, you'll get an indicator light in that switch when operated, and you'll hear the roar of the factory cooling fan...then you'll want to do a search for "refrig fan noise" on these forums to find out the ways you can quiet that beast down. Seriously.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 05-14-2007, 04:33 PM   #8
Dan
djfrantic's Avatar
Thumbs up reefer fan
jd thanks....I have noticed that an indicator light DOES go on after I have been plugged in or charged up a while....but I have NEVER heard the fan running whether the switch was toggled up or down...which now makes me think that I either have the quietest fan ever...or it isn't working.....I am going to poke around in there and see if it is plugged in etc etc.....and check the fuse box also....thanks for the info !
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 06:31 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
