Old 04-20-2017, 04:42 PM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Where are folks buying the Vitrifrigo DP-150 12 V/120 V? All I can find is outlets in Australia using google.
MICHAEL
Old 04-20-2017, 08:13 PM   #16
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
My experience running refrigerator on 12v
My Dometic refrigerator draws about 3 amps on 120v and 33 amps on 12 (measured with a Trimetic meter) when run with a 450 watt modified sine wave inverter.
Based on that, if you have a single group 24 battery with about 75 amp hours, you could run your refrigerator about 1/2 hour before risking damage to your battery.
In my case, I have 300 amp hours of batteries plus 400 watts of solar and I can run my refrigerator with the inverter while driving for 5 or 6 hours and have from 0% to 8% battery drain depending on sun, clouds etc...
rvb is offline   Reply With Quote
Old 04-20-2017, 11:31 PM   #17
2017 27' International
Sioux Falls , South Dakota
"Where are folks buying the Vitrifrigo [refrigerators]?"
Sure Marine Service. They sell Vitrifrigo, Isotherm, and Novakool 12 V compressor refrigerators in a variety of shapes and sizes. (And Force 10 all-stainless marine stoves--my new Airstream will be getting one of those as well! :-)
Paprika is offline   Reply With Quote
Old 04-21-2017, 06:45 AM   #18
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
I purchased the DP2600 model and I believe that I bought it from Bay Marine in San Diego....
https://baymarinesupply.com/refriger...rigerator.html
More info and photos (my actual unit is on page 2) at this URL:
http://www.airforums.com/forums/f37/...ge-111925.html
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Old 05-10-2017, 07:39 PM   #19
1972 25' Tradewind
Los angeles , California
Originally Posted by Paprika View Post
I'm with CA_tallguy. I installed a Vitrifrigo DP-150 12 V/120 V compressor fridge in my motorhome last fall, and plan to do the same to my Airstream 27FB later this year. My propane usage is greatly reduced, there's no worry about fire, and no need to shut off the fridge at gas stations... I love it! Electric power consumption is typically about one sixth that of a standard RV absorption fridge operated from an inverter. The only drawback is the cost--these compressor fridges are about 40% more expensive than standard RV fridges. Well worth it to me, though!
Hello there,
We just purchased 72 Tradewind 2 weeks ago and we were wondering what exactly do we need to run only electrical fridge as you mentioned? If we install 2 or 3 batteries in our trailer and solar panels.. would it be enough to support the fridge? Thank you. Aras.
Spookies is offline   Reply With Quote
Old 05-10-2017, 08:23 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Depends on the refer size and solar panel capacity.
You will also need an inverter with ample capacity to start the compressor in the refer. It should be a pure some wave inverter.
Inverters of the size required to start a refer will require heavy duty wiring and ample protection (fuse) between the inverter and the battery(s).
Old 05-10-2017, 10:41 PM   #21
1986 31' Sovereign
Miami , Florida
For the Vitrifrigo, you don't need an inverter at all. When running, the Danfoss compressor pulls about 6 amps of 12vdc as I recall. The duty cycle averages about 50% in a reasonable climate so figure 72 amp/hours in a 24 hour day. Tough on a single battery, better with two, perfect with solar.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-11-2017, 08:05 AM   #22
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
All you need with a Vitrifrigo is a bucket full of money.
Old 05-11-2017, 10:04 AM   #23
1986 31' Sovereign
Miami , Florida
True that. But I am still going that way when my Dometic finally gives it up.
Young, lovely bride
Old 05-11-2017, 10:35 AM   #24
extiger's Avatar
2011 30' Classic
Kingwood , Texas
I replaced the Dometic with the Vitrifrigo last Fall and have been extremely happy.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 05-11-2017, 11:20 AM   #25
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Have you priced a new Dometic lately? They're not bargains either... the Danfoss fridges are in the same ballpark price-wise with propane models.
— David
Old 05-11-2017, 12:24 PM   #26
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Yes I have and WOW to both. Not sure what I will do when the refer in my '74 Argosy finally quits.
Old 05-11-2017, 11:27 PM   #27
1972 25' Tradewind
Sorry as I do not know the electrical system terminologies yet.
I am planning to buy 2 Interstate Deep Cycle Group 27 batteries + Solar Panel (don't know which one yet). Do you think so that will be enough? Some says I need inverter some says no.. not sure how to proceed here.
Thanks a lot
Aras
Old 05-11-2017, 11:40 PM   #28
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you plan to use a mini refer you will need an inverter unless you are going to be plugged in to shore power.
If you go with the "V" refer no inverter necessary. It runs on 12 volts.
12v
Question: Can you keep the refrigerator on while towing? Scott J-24 Refrigerators 59 11-25-2015 09:53 PM
Wardrobe Doors - To Keep or Not To Keep? Rhino33 General Interior Topics 2 10-07-2015 04:34 PM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 04:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 11:58 AM
