Old 05-04-2013, 05:16 AM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Can a 30AMP 240v provide 2 30AMP 120v??
Hi guys, looking for some enlightenment from the electrician here in the forums.
just wondering is based on the same concept that:
1) 50AMP 240v provides 12000W (50A x 240 V) We see very often the Y adapters for 2 30Amp 120V
2) Can a 30Amp 240 that provides 7200W (30A x 240V) be used to split 2 30Amp 120V??
According to our obvious limited knowledge in the electrical field isn't the same principle?
thanks for your time!!
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 05-04-2013, 07:31 AM   #2
1984 31' Sovereign
charleton , Illinois
Not sure where your going with this but I'll try.
Campers use a 120V / 30 amp hook up OR a 240V / 50 amp.
Have never seen a 240V / 30 amp at a campground, or
a camper wired for 240V / 30 amp.
All 240V systems are two 120V legs to a common "neutral" regardless of amperage.
The adapters that allow a 240V / 50 amp camper to use a 120V / 30 amp outlet has an internal jumper wire that ties both 120V legs together. This allows all the 120V circuits to be powered in the camper, but too much demand will overload the 120V / 30 amp supply and trip the circuit breaker.
jerry d is offline   Reply With Quote
Old 05-04-2013, 07:48 AM   #3
Images: 59
Many generators have 30a 240v outlets. If you want to run two separate trailers from a single generator, make sure ther is only one N-G connection and you have a good ground at the generator.
Old 05-04-2013, 08:10 AM   #4
1981 31' Excella II
New Market , Alabama
I think you can get two 120V 30A connections out of a 30A 220V connection but I am having trouble with the current in the neutral. I would think that two 120V connections would draw 60A through the neutral but I think it is probably 30A. I am having trouble with this. When you are running 220V nothing is going through the neutral. You definately need to make sure the nuetral feeding the recepticle is the same gage as the two hots. Which should be #10. So you would need 10/3 and preferably an independent ground. I run my trailer off a stove outlet in my dad's utility shed by pulling one leg off that. But if you ran two trailers one off each leg, I am worried about running too much current through the neutral.
I know that the feed coming into a house has 3 conductors of the same gage.
Perry
Old 05-04-2013, 09:10 AM   #5
1974 Argosy 20
Kooskia , Idaho
No, you cannot use a normal 30 amp 120 volt RV cord to supply two 30 amp circuits. There are only 3 wires in the cord. One is the hot leg, one the neutral and the third is the ground.
In a 50 amp cord there are 4 wires. Two hot legs, one neutral and one ground. When wired properly the neutral only takes the difference current between the two legs, not the sum current as in effect the two hot legs are the outside of a center taped transformer and the neutral is the center conneciton. If incorrectly wired, the two legs are connected to the same half of the transformer and the neutral then would have to take the sum of the currents (60 amps) and if the same size, would overheat.
But, in short, the RV cord cannot be used for two 30 amp 120 volt circuits.
Old 05-04-2013, 09:17 AM   #6
1981 31' Excella II
That is what I was worried about. So to do it right you would need a nuetral that would handle 60A not 30A?
Perry
Old 05-04-2013, 09:22 AM   #7
1974 Argosy 20
Kooskia , Idaho
Perry
Yes, if both hot lines were connected to the same half of the transformer wired to the power supply.
The real point is that you don't have enough wires in a normal 30 amp RV cord.
Old 05-04-2013, 09:56 AM   #8
1981 31' Excella II
When I had the back off my trailer I put in a 10/4 pigtail going to a 4 pole twist lock with the hopes of upgrading to a dual 30A system running off a 50A RV recepticle.
Perry
Old 05-04-2013, 10:23 AM   #9
Southwestern , Ohio
The two hot pins of a 240 V, 30 A outlet (for example a welder outlet) are 180 degrees out of phase, so if you connect two 120 V loads to the outlet the current flowing in the neutral is the difference between the two 120 V load currents.
That's why the neutral line coming into your house is the same size as the two hot lines. The most current the neutral ever sees is equal to the current flowing in one of the hot lines when there is no load on the other side.
So in answer to the original poster's question, there is no reason you couldn't fan out a 240 V, 30 A outlet to two 120 V, 30 A RV outlets, as long as the 240 V, 30 A outlet has a neutral line (a 4 prong outlet). Not all 240V outlets do.
Nuvite-F is offline   Reply With Quote
Old 05-04-2013, 12:05 PM   #10
1981 31' Excella II
I thought there was something I was missing. It has been 25 years or so since I took Circuits 1.
Perry
Old 05-28-2013, 06:20 AM   #11
1973 31' Sovereign
2007 20' Safari SE
thanks for all the replies, as always Airforums is a great community!!
Well the whole issue here is that we have a generator cord rated 30AMP 240 (4prongs) and we were wondering if we can use that cable & install a 30Amp 240V Outlet to have 2 trailer plugged with full 30Amp.
I see that there is still a split decision whether "yes" and "no".
We are planning on installing a 50AMP 240 and have the "Y" adapter to 2 30Amps 120V but since we have the generator cord that could save us a ton of funds that can be very useful for some aluminum...
2 chronicles 7:14
Old 05-28-2013, 07:15 AM   #12
SteveH's Avatar
Common Sense , Texas
Nuvite-F has it correct.
Regards,
Steve
Old 05-28-2013, 08:35 AM   #13
2008 16' Safari
Destrehan , Louisiana
You should have an electrician check the wiring of you 240/50 amp circuit.
Not all 240 circuits were provided with a neutal line that was large enough to carry the 120 neutral. What you need is a 4 wire circuit. Two 120 hot leads, one neutral and one ground circuit.
A 50 amp circuit would be a 8 AWG wire. You need at least a 8 AWG neutral and a ground wire (usually green or bare wire).
Some 240 vac circuits only provide two hot leads and a ground. This would not be suitable to split for two 120 vac circuits.
Have it checked out.
And,yes, I am an industrial electrician.
dlb435 is offline   Reply With Quote
Old 05-28-2013, 08:46 AM   #14
dznf0g's Avatar
Oswego , Illinois
So, I have a 4 prong 240V outlet for an electric stove (unused, I have gas) right on the other side of the garage wall. What do I do to convert it to a 30 amp, 120V RV outlet if I moved it through the wall?
-Rich-
