Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 10-22-2003, 04:46 PM   #1
TexasStars's Avatar
Profile:
Cable tv question
Hello all,
Question is in my 87 345 M/H is it wired for cable television as there is a screw in plug outlet mounted on rear bedroom wall and coax under the front table that leads to which looks like a booster box which I assume goes to roof top antenna. After more investigation I found a coax coming out of the drivers side compartment that houses the electric and water and connected it this weekend at the campsite cable box which was on to see if I cable... nothing happened so when I got home I ran a new line from the rear bedroom to which I just installed a tv into the wall to the underbelly compartmentand tied in and got cable. I cannot figure out why I can't get cable with the old coax and thought someone might know the answer before I try and figure out how to run another line from table in front to the same location in the rear, seems like that will be a real hassle.
TexasStars is offline   Reply With Quote
Old 10-22-2003, 07:10 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
If you have a winegard booster you need to have the switch, or light off to feed the signal thru. If the booster is on it oly sees the antenna.
The feed will run from the outside connection to the front box, and from the front box to the rear connector.
Good luck on your troubleshooting
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-22-2003, 07:46 PM   #3
TexasStars's Avatar
Profile:
I will try that 1st thing in the morning as that is the booster I think I have and this A/S is so new I am still trying to figure everything out.
Old 10-23-2003, 11:28 AM   #4
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Send a message via AIM to 1985air345 Send a message via Yahoo to 1985air345
Brett and I re-did mine last Thanksgiving. I still have the documentation if you need it.
The Winegard plate has
Front - Out to TV
Back -
(1) Antenna input (switch in - light on)
(2) Cable input (switch off - light out)
(3) 2nd TV out
The plate in the rear of your 345 is fed from the front.
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 10-23-2003, 04:35 PM   #5
Dr Joe
winner's Avatar
Profile:  Central , South Carolina
On our l987 345, the primary control for both of the TV's is in the table in the lounge. When that switch is turned on (red light) it activates both boxes- the one in the front and the one in the bedroom. The cable connection located in the right rear compartment is adjacent to the phone connection.
Dr Joe & Winn
Emeritus Airstreamers
KD8VD
winner is offline   Reply With Quote
TV antenna questions cindy Audio, Video & TV 16 05-13-2006 08:49 AM
Dish Network vs Direct TV gwsullivan Electrical - Systems, Generators, Batteries & Solar 36 01-17-2005 02:49 PM
The Cable Guy PeterH-79MH Airstream Motorhome Forums 1 11-18-2003 10:31 PM
Thoughts on flat screen tv yukionna Off Topic Forum 15 09-16-2003 08:40 AM
Satelite TV Question hex Our Community 6 09-09-2002 09:11 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
