Old 09-26-2014, 02:40 PM   #1
reinergirl's Avatar
Hollis , New Hampshire
Cable ties? Am I creating a potential problem?
I just started attaching cable ties like in the picture and then I started to think that maybe with the vibration from being on the road maybe these aren't such a hot idea? Will they chafe the wire?
I was using them to organize/support the wires and keep them against the back insulation (and away from drill bits) Because there is no pink insulation, my thoughts were that the wire would flop around too much.
There will be another layer of insulation on top of what is pictured.
Your thoughts?
reinergirl is offline   Reply With Quote
Old 09-26-2014, 02:47 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I think you're fine.
Chris
Minno is online now   Reply With Quote
Old 09-26-2014, 02:48 PM   #3
dznf0g's Avatar
Oswego , Illinois
Me too
-Rich-
Old 09-26-2014, 02:52 PM   #4
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Same here...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 09-26-2014, 03:19 PM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
No problems with that. You could use what the factory used in '63, masking tape.
Lance
Top is offline   Reply With Quote
Old 09-26-2014, 03:25 PM   #6
reinergirl's Avatar
You guys are THE BEST! thanks for the fast response. Back to my cable ties .... And foam tape on the ribs. Going to be a busy weekend!
Old 09-26-2014, 03:39 PM   #7
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
IMO one is always better off stabilizing loose wires in the walls, or wherever. I have noticed at the factory, they do not seem to do this… No Comment….
However, i might suggest, before adding any additional insulation or cover you photograph every wall that has wires with clear reference points,i.e., ruler to a wall, or ??? But, if it is required you drill a hole in a wall, you can reference the photo and will know where NOT to drill a hole.
In terms of wiring, I like to put in a loop, so as to allow the wire some freedom if i have to pull another wire, it gets pulled out to cut a new end, for any reason one might need slack in a wire.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 09-26-2014, 04:49 PM   #8
1981 31' Excella II
New Market , Alabama
Nothing wrong with what you did. You do need to make sure that all wires going through ribs are protected. I like to use rubber hose like you would use for fuel lines. You slit the hose lengthwise then wrap it around the wire that goes through the rib. Then you ziptie the hose to the wire so it won't move. As long a metal does not touch it, the chances of the wire getting damaged are small. I had a wire in my house rub against a copper pipe and it rubbed a hole in the pipe and caused a water leak. The wire looked like new but the pipe had a hole in it. I think Airstream used a few of those stick on mounts in a few places in my trailer.
Perry
Old 09-26-2014, 05:02 PM   #9
Baltimore , Maryland
I used to do this but found that A) is cost a lot to buy the bases and ties. B) when the heat gets to the bases the glue gives up the ghost and they fall off. C) a small square of aluminum tape does not heat up and come loose. D) a small square of aluminum tape holds the wire very tight with zero movement. E) a small square of aluminum tape is very easy to slice with a razor knife and relocate the wire when you change your mind.
Old 09-26-2014, 06:29 PM   #10
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Thank you Frank. Great idea and I hope I remember it when the time comes
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 09-26-2014, 06:53 PM   #11
Lake Forest , Illinois
I am wiring the inside of my 72 Land Yacht now - remember, as technology changes, you might want access to these wires - putting them inside of loop is a great idea - and shrink wrap will keep them from chaffing in the future. Vibration happens.
Don't forget CAT5 cables and HDMI cables to both the front and rear.
Good luck
Paul
PJBWFG is offline   Reply With Quote
Old 09-26-2014, 06:55 PM   #12
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Look's good to me. I have to say, this is one of the very few times when I've seen 3 or 4 people agree on something....maybe there is hope...
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Creating a home "dump station" TG2500 Waste Systems, Tanks & Totes 78 03-22-2017 09:28 AM
Views on using Simpson Strong-Ties as Hangars for Tanks DanielB Repairing/Replacing Floor &/or Frame 5 01-08-2011 12:46 PM
Creating a spare for the spare easyride Tires 0 06-10-2008 05:16 PM
Vintage Airstream Bolo Ties and 2 Badges PeeWee Off Topic Forum 2 03-25-2008 01:58 PM
Creating a permanent Airstream Site gadgetat Full-Timing 12 05-25-2005 08:13 PM
