Old 10-13-2005, 12:12 PM   #1
1994 30' Excella
austin , Texas
Cable Splitter
I have a 30' 94 Excella. The TV cable signal coming into the trailer is strong, however, the signal coming out of the walls is weak. We think the problem is at the splitter but cannot find it. The manual does not pin point the splitter location or tells you how to get at it. Any answeres out there?
jhobbs is offline   Reply With Quote
Old 10-13-2005, 12:17 PM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Maybe amplifier
Is the amplifier turned on?
smily is offline   Reply With Quote
Old 10-13-2005, 12:28 PM   #3
1994 30' Excella
austin , Texas
I believe it is if "on" is signified by the little red light that is next to the coax outlet.
Old 10-13-2005, 12:53 PM   #4
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Are you talking about the cable signal from the external antenna, or the signal from a cable service? If from a cable service, I bypass the amplifier altogether. If it will help, there is a picture of the bypass arrangement in my photo gallery. I just unhook the top cable, and run a short cable directly to the television.
SilverRanger is offline   Reply With Quote
Old 10-13-2005, 06:24 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i found my splitter under the antenna, i had the same problem. bad connector.
if you remove the crank and the adjuster plate from the ceiling you should find it. it is tucked up in the insulation.
john
you call them ferrets, i call them weasels.
Old 10-14-2005, 02:31 AM   #6
desi arnaz's Avatar
oops........................i just hooked a dish up in the hole meant for the antenna.am i going to have a problem using the coax for the antenna?
desi arnaz is offline   Reply With Quote
Old 10-14-2005, 11:02 AM   #7
Still Working
smily's Avatar
1994 36' Classic 36
Amplifier noise
If you are trying to use cable input from a Commercial provider (cable company) then yu want the amplifier to be in the OFF position.
If you are trying to use the Air antenna (crank up), you want the amplifier ON.
The amplifier will induce noise onto the line if you are trying to use Cable TV.
TV antenna questions CindyH Audio, Video & TV 16 05-13-2006 08:49 AM
Break-away cable broke... crazylev On The Road... 9 08-16-2004 06:24 PM
The Cable Guy PeterH-350LE Airstream Motorhome Forums 1 11-18-2003 10:31 PM
Towing Without Brakes? MattyBoy Brakes & Brake Controllers 31 09-17-2003 11:08 AM
speedo problems wb13798 Mechanics Corner - Engines, Transmission & More... 16 03-28-2003 03:07 PM
