Old 08-17-2014, 09:13 AM   #1
1978 31' Sovereign
1988 32' Excella
Linthicum , Maryland
Buying Generator
Hi, need some advice here. Am in the market for a generator. As is - Honda 2000i or Powerhouse Portable Inverter Generator 2700 W. Does anybody have any experience with the Powerhouse ?
Recommodations, plz
RuneM46 is offline   Reply With Quote
Old 08-17-2014, 09:34 AM   #2
terryV's Avatar
2002 31' Classic
Monroe , Iowa
No, but I have a Honda 3000 with electric start and a Yamaha E2800i tri power. Both are inverters, both are very quiet, and both will power the AC, 'fridge on electric, lights, water pump, and converter at the same time.
The Honda is 134 lbs. and too big to fit under the tonneau cover of PU, so it stays at home.
The Yamaha weighs 70 lbs., fits in the PU, and can be operated on propane, so it gets to go camping.
terryV is offline   Reply With Quote
Old 08-17-2014, 05:03 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
There are many many threads on the Forums discussing generators. Honda and Yamahas are generally the most recommended because of their reliability, great service and quiet operation. You won't go wrong with either of these brands. I do not know anything about the Powerhouse brand, sorry.
Your needs and projected uses will dictate the size and type. We chose to go the two-Honda-2000w route, one of which is the "Companion" model which has a 30-amp outlet built in and allows for ease of paralleling the two to create 4000w for those times we need AC. A single 2000w will run everything else in our 19'. We went with the two 2000s because we don't always need to take two and they are only about 40 lb each. Weight was a factor for us.
Good luck with your search.
TB & Greg and Abbey Schnauzer
#3954
Old 08-17-2014, 05:31 PM   #4
batman's Avatar
1964 22' Safari
modesto , California
What TBRich said. Doubled. We love our EU2000i's.
batman is offline   Reply With Quote
Old 08-17-2014, 05:38 PM   #5
1966 17' Caravel
Bethel Park near Pittsburgh , Pennsylvania
Send a message via Skype™ to aceflys
I got one a few months ago. I am very happy with it. It runs smooth and startes very easy. Here is the link where I got mine.
EU2000i
Ace in Pa
WBCCI 2169
TAC PA-1
Proud Owner of a
1966 Caravel
2015 Shasta Retro
aceflys is offline   Reply With Quote
Old 08-19-2014, 07:39 PM   #6
1978 31' Sovereign
1988 32' Excella
Thanks to all who came with inputs in regard to generators. Changed my mind and went with a Champion 3100W. Only $850. Delivered today by UPS. Picture in the ad lies! Generator is bigger than expected. Testrun tomorrow.
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Thinking about buying a Generator. Anyone have any suggestions? Blockstream Generators & Solar Power 16 07-19-2012 06:33 PM
Advise on buying used Honda generator... asta2 Generators & Solar Power 11 07-30-2006 02:05 PM
Buying a CCD Ed L 2002 - 2005 International 30 04-21-2003 03:14 PM
Question about a buying decision! escapeez Our Community 7 08-15-2002 02:29 AM
