Old 05-04-2014, 05:27 PM   #1
2014 27' FB International
Santa Rosa , California
Breakers in 2014 International
This weekend we were over 100 degree weather, had A/C, vent fans, and micro going. We were hooked to 50 AMP service at RV park. 20 Amp breaker tripped twice, once with only air and vent fans on, the other when Micro, A/C were going. Does the breaker need changing out? Also, is it possible to upsize the standard A/C?
NatandGregg is offline   Reply With Quote
Old 05-04-2014, 05:30 PM   #2
K.C. , Missouri
I wonder what the line voltage was at the park ? Did you have a good surge protector connected up ? One that would power down in case of low voltage.
EDIT: ps, I am not saying that "is" what it was, I'm just wondering if it might have been the problem or part of the problem.
gmw photos is offline   Reply With Quote
Old 05-04-2014, 05:44 PM   #3
1974 Argosy 20
Kooskia , Idaho
I could be low voltage at the campground, or it could be a breaker or wire tightness issue which on a 2014 should be handled by Airstream under warrantee.
It may be hard to duplicate at the dealer of course.
Why are you running the vent fans (I assume the Fantastic Vents in the ceiling) while you are running the AC? That will only pull hot air in through every crack in the trailer and can easily overcome the AC cooling capacity.
Old 05-04-2014, 08:58 PM   #4
2004 16' International CCD
Chicagoland , Illinois
It is unlikely that your circuit breaker is bad. If you do decide to replace it you'll want to make sure that you don't install a larger breaker in it's place.
While a larger breaker might eliminate tripping, it will also increase the probability of a nasty fire.
Airrogant is offline   Reply With Quote
NorCal : 2014 Jackson Rancheria Rally, October 10-12, 2014 Coastalview Forum Rallies & Meet Ups 240 01-03-2015 02:04 PM
Circuit breakers in '09 International 25FB donna01 Electrical - Systems, Generators, Batteries & Solar 6 03-13-2011 02:15 PM
70 amp breakers livexl Classic Motorhomes 0 03-07-2006 07:21 PM
Circuit breakers,94 33ft Motor Yacht rayschell Batteries, Univolts, Converters & Inverters 4 07-10-2005 11:35 AM
Electric Heaters Tripping Circuit Breakers streamlean General Motorhome Topics 11 01-20-2004 09:29 PM
