Old 01-23-2014, 08:15 AM   #15
beerob63's Avatar
1990 36' Land Yacht
San Antonio , Texas
Breaker Tripping Issue Solved!!
Greetings again,
After EXTENSIVE troubleshooting (and some experienced guidance from a local expert) it was discovered that an inverter (installed in 1989) blew which provided power to the affected outlets. We decided to remove the inverter and hard wire that circuit....worked like a charm. The little power surge from the heater also destroyed the 1989 10' back up camera TV monitor (which I wanted to replace anyway). This little error in judgement cost me a few Benjamin's, but provided a valuable lesson. Thank you to everyone for their input, it really aided in my continued education!
Bryan
1990 Airstream Land Yacht
beerob63 is offline   Reply With Quote
Old 01-27-2014, 11:07 AM   #16
2012 30' International
Key Largo , Florida
I have breaker with a test button on it that I switched to off and it will not now reset. Any suggestions please
Martin R is offline   Reply With Quote
Old 01-27-2014, 03:54 PM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Martin R. Did you actually flip the handle on the breaker to the "off" position or just push the test button?
Old 01-28-2014, 02:17 AM   #18
Key Largo , Florida
Yes, I flipped the handle. I have replaced the breaker now with a new GFCI breaker and it seems to be fine so I think it was a simply a bad breaker
