Old 04-30-2015, 04:36 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Breaker box options
We are looking to get the wiring hooked up in the trailer. Last summer she was gutted and I redid all of the wire runs- 120 and 12 volt- with new wire.
I have a 20 amp line for each the microwave and AC and a few 15 amp lines for "regular" receptacles.
Can anyone recommend a breaker box for the Airstream? My electrician friend told me to just go with one from a big box home improvement store...can anyone give me specifics on what they used for a new breaker box?
Thanks!
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 04-30-2015, 05:22 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Hi Ben,
I usually don't reveal my sources, but there is a perfect 120VAC/12VDC power center for your needs made by Progressive Dynamics. It even has one of their 3 stage converters integrated into it. It is called the 'Mighty Mini' and you can find it here: Mighty Mini All-In-One System AC/DC Power Distribution Panel and Inteli-Power Converter
Have fun!!!
Old 05-01-2015, 07:25 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Ben,
I also highly recommend the Progressive Dynamics unit Lewster pointed you too. It's fairly compact, easy to install and wire, and will handle all your power needs. The converter has a jumper you install for AGM batteries, so it'll charge them properly if you go with AGMs. We've been using ours for 6 years without any issues.
You can buy a home style breaker box and use that, but then you still need to buy a converter and a 12 volt fuse panel. If you go that route, be sure to buy a tri-stage converter.
Chris
Old 05-01-2015, 05:54 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I wish I had researched the Progressive Dynamics product. I went with a standard home style breaker box. It has room for 8 circuits of which I used 4 of them. It takes quite a bit more room. And I mounted a 12v fuse panel on top of it. It all works, but not the most elegant system around.
David
Name:	1404 Electrical New Breaker Box.jpg
Old 05-01-2015, 06:10 PM   #5
lewster's Avatar
This is one of the power center arrangements that I use (minus the covers) when re-wiring an entire trailer. It replaced the old Parallax converter, breaker box and fuse panel.
Old 05-02-2015, 08:17 AM   #6
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
Originally Posted by lewster View Post
Hi Ben,
Have fun!!!
I wish I had found this when I replaced my Argosy converter. Definatly a must when I get to the Sovereign! Thanks Lewster!
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 07-03-2015, 11:45 AM   #7
54 Flying Cloud
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
Taking your word and buying one. You're all to blame if my camper blows up <eg>
KrisE MN is offline   Reply With Quote
Old 07-03-2015, 03:57 PM   #8
lewster's Avatar
Now you know why I don't give specific advise if I'm not directly involved in a project. Not worth the liability exposure. :-))
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-03-2015, 06:46 PM   #9
54 Flying Cloud
KrisE MN's Avatar
I don't have that good a memory considering everything I am buying. besides...the judge says there's too many lewsters out there. ��
Old 07-03-2015, 10:28 PM   #10
1979 23' Safari
Wayland , New York
Unless you rerouted all the 120v and 12v so the wires terminate in the same area the combined PD center may be more work than you want. You can just get the smallest breaker box at the big box that will give you enough slots, as described it'll probably be a 100A box that's just a bit bigger than the original and will hold about 8 breakers.
On a trailer the ground stays separate from the neutral. Don't forget to ground to the frame.
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Breaker, Breaker!! Bing-Bing Generators & Solar Power 25 09-24-2013 08:25 PM
breaker breaker project66 Batteries, Univolts, Converters & Inverters 4 05-29-2012 08:37 PM
Breaker Box for Sale jlawrence Electrical - Systems, Generators, Batteries & Solar 1 04-25-2004 09:48 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
