Old 08-09-2013, 10:52 PM   #1
1971 31' Sovereign
fresno , California
breakaway switch
Having problem getting power to switch. Are there any fuses or other issues I need to deal with. I would appreciate any insights. 1975 Tradewind . Is this a dealer problem. My guy is having an issue fixing it.
imbighoe is offline   Reply With Quote
Old 08-09-2013, 11:04 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
The power for that switch should come from the onboard batteries and the charge line from the tow vehicle.
Bill
Just my personal opinion
Old 08-09-2013, 11:08 PM   #3
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
The breakaway switch should have power direct from the trailer battery somehow. The breakaway cord should be long enough to not pull the pin until the trailer umbilical comes apart. The breakaway should not be activated while the umbilical is connected to the tow vehicle.
In reverse order, test your breakaway while hooking up, before connecting the umbilical to the tow vehicle.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 08-09-2013, 11:56 PM   #4
1976 31' Sovereign
South Jordan , Utah
What exactly is the problem? How do you know you don't get any power to the switch? I ask because, in testing out the breakaway switch on my 1976 31' Sovereign, I found that, even after pulling the activator pin, the brakes wouldn't lock. I decided to take the switch apart and explore inside. I found that, over time and lack of use, the two copper and brass strips that should make contact and complete the circuit when the pin is pulled were separated, and had not enough internal spring to touch. Some bending, test fitting, cleaning, then two new rivits and a little sealant to keep it watertight and it is as good as new. Could this be your issue?
If there really is no power to your wire, and your battery is connected in the trailer and working, there could be another problem. There are circuit breakers (self resetting) just behind where you plug the umbilical cord in from your tow vehicle to the trailer (at least on mine). I had to remove the gaucho to get to (actually, not as hard as I thought it would be). After getting the cover off, I was able to inspect the breakers. (I actually thought they were fuses, from the wiring diagram). All were tight. A little rust, but the connections were all good.
shane_franz is offline   Reply With Quote
