Old 08-04-2013, 05:50 AM   #1
1988 25' Excella
Roanoke , Virginia
Brand newbie...plug in excella to house?
1-day new owner. Have a '88 Excella now in my driveway. Bought a power adapter so I could plug the rear power cord into my home's exterior outlet with an extension cord. I was thinking I could do this to use the interior AS lights for cleaning, etc without having the batteries on and draining them. All connections are good, but I am not getting power to the unit? I have to turn the batteries on to get power. Wondering if I am missing something here?
When we bought the AS, the previous owner had the power hooked up to a household plug while the batteries were disconnected and being recharged....and all of the lights worked well. I have ordered an owners manual/technical manual but was hoping to get some insight. I was planning on doing the same (using an exterior power supply) @ a remote location where the AS will be kept...need help!
Thanks for helping to educate an ignorant new owner.
VaBill is offline   Reply With Quote
Old 08-04-2013, 05:58 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Use test light to be sure the 110 is reaching the trailer. Check 110 outlets in the trailer that it is getting that far. Check to see if the battery leads are not touching each other and shorting out the converter. See if the battery master rotary disconnect switch, behind the couch, is turned on. Check that the plug that connects to the converter is plugged in. Check the 12 volt output from the converter is there. Check the main fuses from the converter on the main 12 volt panel.
Old 08-04-2013, 06:12 AM   #3
1988 25' Excella
Roanoke , Virginia
Thanks....so, even with the unit plugged in, the battery master switch needs to be turned on? if that is so, i should assume that when the previous owner had the batteries out and charging them, and the AS pluuged in to their house, they still had the master battery switch on?
Old 08-04-2013, 06:58 AM   #4
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
Yes, the way the Trailer is engineered is the fact that most everything that "runs" in the unit is 12V. In order to have lights, water pump, heat, etc; one needs to have that switch turned to ON. It really isn't a problem whether the batteries are in or out. When you turn it to OFF is when you want to totally shut down the trailer.
The drawback to having the Trailer plugged into the house is the fact that the inverter/battery charger is sitting there humming away. This really isn't a problem either except that it can and will overcharge the batteries. Lots of folks get around this problem by leaving something running, radio, a few lights, exhaust fan, etc that will burn off the excess amperage.
Yes, YOU NEED TO HAVE A HEAVY DUTY CORD if you plan on running the AC......God bless.....Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 08-04-2013, 07:03 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Lights are 12v so the battery has to be on for the lights to work. Plugs are normally 110v so you could plug a lamp in and have light.
Aaron
WBCCI #XXXX AIR #2495
Old 08-04-2013, 07:08 AM   #6
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
No, the batteries should not need to be connected to have 12 volts in the trailer.
As for the master switch, some previous owner may have changed it, but it should only disconnect the batteries from the system. Not the converter. Meaning it should be ok for it to be off and still have the converter power the inside of the trailer.
Check to make sure you are getting 120 volts inside the trailer. Turn on the TV, look for a light on the microwave, plug a drill or hairdryer in a outlet.
Check the outlet you have the extension cord plugged into. Ground Fault Interrupt circuits don't like trailers sometimes.
Good Luck, and welcome to the forums!
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-04-2013, 07:31 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That is correct. Nothing works until you turn on the converter.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-04-2013, 07:32 AM   #8
1988 25' Excella
Roanoke , Virginia
Thanks for all of the replies. You all are fantastic!
Old 08-04-2013, 07:32 AM   #9
m.hony's Avatar
2013 30' Classic
But, when you turn on the converter to run the lights while cleaning or loading and have the trailer plugged in to a receptacle it is charging the batteries as well.
TAC #MS-10
Airforums #70955
Old 08-04-2013, 08:12 AM   #10
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I haven't seem mentioned here, BEWARE, don't try to run the AC while plugged in unless you upgrade and provide a 30 amp service. Your household is likely to be 15a or 20a only. Thats more than enough for everything except the AC and maybe the microwave
( if you have one ). The factory provided convertor will not do well plugged in for the long term but if you upgrade to a modern multi-stage one you will find them much more battery friendly and can handle being plugged in long term. So take a look and see. If it's a Parallax 55amp don't leave it plugged in continually. The good ones are not that expensive and are easy to install so you might consider it a homecoming gift to your AS.
Take care of your Airstream and it will take care of you for many miles.
ENJOY
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 08-04-2013, 01:39 PM   #11
1988 32' Excella
Robbinsville , New Jersey
Some Airstreams have a "light switch" that turns the converter on and off.
Old 08-04-2013, 01:51 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Pics where are our pics of proud family?
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-04-2013, 03:56 PM   #13
1988 25' Excella
Trumbull , Connecticut
Excella battery switch
Hello All. Congratulations on your 88 25' Excella, that is a great size trailer.
On my 88 25' Excella the battery disconnect switch only disconnects the batteries and thats all. Every thing will still work including 12VDC operated things as long as the converter is operating and the trailer is pluged into 120VAC shore power. My 88 manual also states that it is NOT recommended to operate the trailer with the batteries disconnected if you have the original UNIVOLT converter in the trailer as they are not highley regulated and rely on the battery to keep from overvoltage on 12VDC. If the PO has replaced the original converter with a new smart converter then you don't even need to have batteries as they are regulated but you would be relying on the TV for 12VDC power while towing.
If you are connected to shore power and the battery disconnect switch is off then the converter will not charge the battery. Anyway this is how my 88 Excella works.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 08-05-2013, 10:18 AM   #14
janeinthemtns
1985 31' Excella
near Chama , New Mexico
What do I look for in a heavy duty extension cord? I've got a long one that I use to run electricity upstairs during the summer in the old adobe house. I plan on plugging my Airstream into a 20amp circuit in my house. How do I know if the batteries are getting overcharged and/or how many lights or whatever I need to leave on? I can't get to the converter to see what it is. It's under the couch. Apparently, my factory installed solar panel is not charging the batteries. There is a wire coming through the back vent into a little box that says it's charging, but the batteries were dead in a week with nothing running. When I looked at the batteries when I got the trailer home, one of them was disconnected. The other one was well charged from the drive and also the trailer was plugged in at the POs house and Holiday Trailer in Albuquerque where everything was checked out and working. If I use only 12v lights, will I be able to use an electric heater in there? Sorry if the questions are too dumb to be believable and thanks for information! So far the only thing I've got figured out is how to back it up. I've lived and worked on cattle ranches and hay farms for most of my life backing up big things into small crooked spaces.
janeinthemtns is offline   Reply With Quote
