Old 05-27-2007, 08:01 PM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by campadk
Thanks all for the excellent input...
I like to be on the safe side, so I'll schedule the brakes be checked this week.
Is this something I can have our car mechanic look at (GMC dealer) which is just down the street, or do I need to go to our Airstream dealer which is about a 45 min drive.
Also what has this done to shorten the life of my Interstate batteries.. they were down to almost nothing this morning.
Of course I have since plugged into shorepower as soon as we returned.
Dave,
I don't think that most car mechanics know anything about electric brakes. Hydraulic disc and drum brakes...YES but electric brakes are a different animal. You might try a good trailer place if you don't want to go to your Airstream dealer.
Old 05-27-2007, 08:12 PM   #16
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Take it to the Airstream or other RV dealer, or a shop that sells and services large trailers like horse trailers. Electric drum brakes look similar to hydraulic drum brakes but work differently and could confuse a less than sharp auto mechanic. A sharp one could probably figure them out, but then might not know how to ohm them correctly or have replacement parts.
A new pair of magnets shouldn't be that expensive (or used to not be) and the total labor cost shouldn't be that much more than for R&Ring the wheels and drums and troubleshooting.
I forgot to mention it, but I'd take a look at the wheel bearing grease while in there too. (honestly, if I was that far into it, I'd repack them)
Maurice
Old 05-27-2007, 09:19 PM   #17
CanoeStream's Avatar
St. Cloud , Minnesota
I don't expect much from my Mega-Tron OEMs. They'll hit 24 months at the end of the summer. Silvertwinkie has posted that he had a couple near total discharges and his Mega-Trons don't have a lot of capacity any more. He's seriously trolling for what he'll do next. I've never done that and it seems mine aren't great at recharging to full capacity. Anything I get over 24 months is honey -- I don't leave them in the trailer over winter with parasitic loads, low temps, etc -- store them in my basement and put them on a battery minder at least every month. I'll definitely go AGM when I replace. Interstates? See Interstate Batteries-Detroit. Ride 'em as long as they seem to do the job. I've never discharged >50% on my two Group 24s while running my furnace overnight -- includes camping in the upper teens with the interior thermostat set at 62 degrees F.
5 meter Langford Nahanni
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 08:41 AM
Brakes/Univolt Rob Brakes & Brake Controllers 9 10-22-2002 06:50 AM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 09:31 AM
Vintage trailer rally 83Excella WBCCI Rallies & Events 0 08-13-2002 10:27 PM
