Old 11-16-2009, 12:01 AM   #1
sound-silver's Avatar
1978 29' Ambassador
2004 25' International CCD
Moab , Utah
Both Furnace and Water heater won't ignite?
OK... I'm at a loss
We're in the Rockies. It's late. It's cold!
Both the furnace and water heater will not ignite.
Everything else electrical is just fine. All fuses fine.
We're hooked up and have a space heater.
Anyone have a suggestion on what to check?
It's not where you are, but your reason for being there.
sound-silver is offline   Reply With Quote
Old 11-16-2009, 12:08 AM   #2
aluminauti
whitelight's Avatar
Where we , Park it!
Have propane?
1) do you have a propane flame at the stove? If not, then a problem with the propane system
2) how cold is it where you are? don't remember at exactly what temperature propane doesn't remain at its liquid state (-35??) We've used either a 75W light bulb or an ambient heater such as a "goldenrod" near the propane regulator to maximize the efficiency of the propane when the temp gets below freezing.
3) your propane regulator may be at fault - they do fail.
whitelight is offline   Reply With Quote
Old 11-16-2009, 12:14 AM   #3
1978 29' Ambassador
Moab , Utah
Yep, we have gas at the stove. It's about 10 degrees outside.
Thanks for the information. Have to keep at it!
Old 11-16-2009, 07:23 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What is the elevation? Sometimes the furnaces and water heater have trouble lighting and staying lit at higher elevations. Your LP pressure regulator could be slightly misadjusted. I have to run to work, if somebody else doesn't jump in with more detailed instructions, a search of the forums for "LP", "regulator", "water column", should get you to some usable info. Good luck.
Old 11-16-2009, 08:01 AM   #5
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
It was 14 here in Flag at almost 7K and the Suburban worked fine, so Terry may be on to something.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-16-2009, 08:55 AM   #6
1978 29' Ambassador
Moab , Utah
We've been camped here for a few days at about 7k elevation. All has worked fine till last night. All that's changed is temperature which was the lowest it's been last night. Plenty of gas at the stove. The water heater did kick on a few times during the night and the fridge can be switched over to gas.
Time to research the forum some more for a clue.
At least the pipes made it through the night.
Old 11-16-2009, 09:02 AM   #7
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
Does your heater blow air? our circuit board in the heater went out it would blow cold air but not light .Had to take out furnace and replace board.
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 11-16-2009, 09:51 AM   #8
1978 29' Ambassador
Moab , Utah
Actually the heater won't do a damn thing right now. Fiddling with the thermostat doesn't bring it to life in any way. I'm really hoping that it's not a circuit board or other major issue. It's challenging to have this happen when the temp is expected to drop to 10 or so tonight. Have to keep reading on the forum...
Old 11-16-2009, 10:08 AM   #9
Gypsy Jo's Avatar
1977 28' Argosy 28
I don't know? you checked all the fuses? If you don't get it going by tonight I have a mini winterizing tip for your water pipes turn off your pump or outside water source and leave your faucets open. I don't know how well this will work where you are I have been below freezing but not down to 10
Gypsy Jo
Old 11-16-2009, 10:10 AM   #10
Mike Leary's Avatar
Images: 11
If the boards were bad, the units would still come on, but not ignite. It seems to me a wiring problem, you should have a separate fuse for the water heater and the furnace, I do. Hope this helps.
Old 11-16-2009, 10:29 AM   #11
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Being in a cold loaction without
the heater working as it should
is TOUGH. I hope you get this
figured out soon! Do you have
your Operation Manual with you?
It may have a "Troubleshooting Guide"
to help.
kennethowens is offline   Reply With Quote
Old 11-16-2009, 10:44 AM   #12
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I had a the same situation. Heres what my problem was. "Corrosion"
The furnace corrosion was in the thermostat. Mine has a little contact that is made when the switch is turned on. That contact needed slight sanding. The hot water tank, was the connection on the board.
The question might alos be, Does your stove work? because you might have condensation and froze your preassure regulator.
Corrosion is funny, it happens most oftenly at severe temp changes, in damp conditions. This is why Alluminum tires tend to be low, on the first cold mornings
mustang is offline   Reply With Quote
Old 11-16-2009, 12:42 PM   #13
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
try hard crossing the themo wires
'77 Sovereign Intl 31' CB
Old 11-16-2009, 12:52 PM   #14
Mike Leary's Avatar
Images: 11
I would not touch any of that: Our fuse blocks are: RED: stove fan, overhead fan, light in bath and Suburban. BROWN: hot water heater, shower light, water pump, cockpit lites and monitor panel.
water heater/furnace combo tracker Furnaces, Heaters, Fireplaces & Air Conditioning 11 11-02-2006 10:02 PM
Hot Water Heater and Furnace Q's jerrodwong Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-23-2006 01:37 PM
2005 Bambi Hotwater Heater Doesn't Ignite dva1946 Member Introductions 5 07-15-2006 06:28 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
