Old 11-16-2009, 03:34 PM   #15
extiger's Avatar
2011 30' Classic
Kingwood , Texas
On my trailer, 2001 25' SS there is a separate furnace switch. Open the outside furnace panel, drop down the next panel and look for an electrical switch.
One of the first times using the trailer required heat. Reading the manual for about a dozen times, I finally discovered the switch and after looking for it and going back to the manual several times, I found it.
In fact I just flipped the switch to set it up for winter use.
extiger is offline   Reply With Quote
Old 11-16-2009, 03:50 PM   #16
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
So, is there a switch for the hot water, too?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-16-2009, 10:22 PM   #17
sound-silver's Avatar
1978 29' Ambassador
2004 25' International CCD
Moab , Utah
Hey Extiger, Your suggestion worked like a charm!
We only had the general manual on PDF and it didn't cover the heater.
I want to extend a very warm (ha ha) thank you!
It's not where you are, but your reason for being there.
sound-silver is offline   Reply With Quote
Old 11-17-2009, 06:35 AM   #18
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
I am glad you got it working. Found myself concerned
about ya'll yesterday evening.
kennethowens is offline   Reply With Quote
Old 11-17-2009, 07:08 AM   #19
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
good to here it was something simple.who would have thought!! a switch.
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 11-17-2009, 07:30 AM   #20
extiger's Avatar
2011 30' Classic
Kingwood , Texas
Glad it worked out for you!!!!!!!!!
water heater/furnace combo tracker Furnaces, Heaters, Fireplaces & Air Conditioning 11 11-02-2006 10:02 PM
Hot Water Heater and Furnace Q's jerrodwong Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-23-2006 01:37 PM
2005 Bambi Hotwater Heater Doesn't Ignite dva1946 Member Introductions 5 07-15-2006 06:28 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
