Old 11-20-2015, 06:40 PM   #1
OklaOverland's Avatar
Tulsa , Oklahoma
Boondock Restoration
I'm restoring my vintage Airstream in a train yard and recently the electrical plug that I've been using has stopped working. I was hoping to continue working in that area but I need enough juice to use power tools. Is there an inverter that I can run off my car battery that I can eventually use in the Airstream?
I know one of the tools say 12amp 1250W max output but i never turn it up all the way. Thanks for your thoughts.
OklaOverland is offline   Reply With Quote
Old 11-20-2015, 08:24 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Car batteries are meant for starting applications, not the deep cycle type that you need with an inverter. You might be able to use the inverter if your engine is running and the alternator of your vehicle is providing charge to the battery.
Old 11-27-2015, 03:18 PM   #3
Tulsa , Oklahoma
So that would basically turn my car into a generator, right? Or is there a chargeable battery that's meant to be used with a solar panel that I could use? I know the easy answer is to go buy a small generator but I don't think I'd use it once we start camping. If the Airstream isn't plugged in everything will run off battery except the Frige, Stove, and Water Heater that are running off propane. That's why I'm hoping to see if there's an inverter that I can use now that I can use later to run the few 110v appliances. (TV, some lights, etc)
See my progress on Instagram @MonicaTheAirstream
Northeast Has anyone found places to boondock in New England? riverstreet2 Boondocking 21 06-07-2009 07:48 AM
Baja boondock? Boondocker On The Road... 11 10-28-2008 03:46 PM
1st Boondock Experience with 19' CCD crazylev On The Road... 15 11-03-2004 06:44 PM
Northern Alabama; Boondock or Campground? 73ANDY Off Topic Forum 4 05-04-2003 02:24 PM
