Old 09-17-2018, 06:00 PM   #1
Pittsboro , North Carolina
bonding ground & neutral
I purchased a Firman generator which runs and starts easly. When connected to the EMS I get error code E-9 . I think it has to do with ground. How can I fix this. Firman seems to be no help.
David J is offline   Reply With Quote
Old 09-22-2018, 05:21 PM   #2
2015 30' Classic
Pleasanton , California
You need a ground-neutral bond. Here's a link to show you how to make this plug.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 09-22-2018, 07:21 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
When feeding an RV you need to bond the neutral to the ground at the source ( = the generator). You also *should* do something to connect the ground to a "real ground". A spike in the ground is one way to do this, there are other possibilities.
If the generator is feeding a house through the breaker panel, this ground bond is not needed (= don't do it).
Old 09-22-2018, 07:48 PM   #4
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
You can make yourself a homemade 30 amp Dogbone for your generator with a 30 amp plug, single gang box, cover, and a short 10ga pigtail with a 20amp plug
Wire the 30amp plug just like normal but add a short jumper wire between the ground and the neutral. This will bond the neutral outside the trailer and at the power source like it is inside the panel box/shore power supply.
Old 09-22-2018, 09:34 PM   #5
Mollysdad's Avatar
The simplest is to make a cheater plug.
Take a plain old three prong male plug,
Run a jumper wire from the green ground to the white (silver) neutral.
Then while on generator, just plug that into any unused 120v. outlet on the generator.
Neutral-ground in Honda & Yamaha gennies? DarrellT Generators & Solar Power 25 07-16-2018 03:30 PM
Odd electrical ground / neutral issue on '89 370 classic romakdaddy Classic Motorhomes 29 10-23-2013 05:44 PM
Neutral Ground Fault on ciruit 1 ViewRVs Argosy Motorhomes 10 06-05-2013 07:31 PM
Hot Ground/Neutral Reversed Snaken49 Electrical - Systems, Generators, Batteries & Solar 14 08-23-2009 03:27 PM
